popping noise at take off.
Richi5280
oklahoma
I have a 07 denali. I'm getting like a pop sound at take off? I can only hear it up front, think driver side. Might be passenger but it is coming from the front. Is this common? What exactly is it? Is it a shock or motor mount? Any help will be appreciated.
rodwar254
Hampton, Va
Im getting the same popping knows with turn the steering wheel coming out of parking space...I was told its the tie rod flexing...idk tho...
Goodinblack
I Like Tacos
Dirty South
May have to diagnose further.
I had a ball joint go bad on a van, it made a pop on deceleration braking only.
Could be a body mount.
Motor mounts act up under torque. Open the hood and power brake it gently. Check for visual flexing of the block.
Other wise check all the joints..... ball tie rod etc loose rack pinion etc
UCA and LCA bushings as well
Basically take the load of the suspension via lifting it up by the frame. Can use a long pry bar to gently check for flex on certain items.
Richi5280
Richi5280
oklahoma
Yes I will check my ball joints and tie rods. Mine only pops when I first take off or hit the gas kinda hard. Other than that no popping. Coming from the driver side front end. If not I will be a taking it to a shop
Juniorss
Long Island, NY
My truck did this and I brought it in to the dealership a few times. They never figured it out but it just magically stopped doing it one day and hasn't done it in at least a year.
GM Customer Service
Michigan
Richi5280,
Hello! I understand that you are seeking advice on how to resolve this vehicle issue yourself and I might not be able to give you any technical advice. However, if you find that you cannot resolve this yourself, I am more than happy to look into this for you. Please private message me if I can be of any assistance.
Regards,
Jennifer T.
GM Customer Care
UGA Tahoe
Jacksonville, Fl
My Dads 07 had what maybe the same problem and he had to replace the motor mounts.
Sent from my SCH-I535 using Tapatalk
Richi5280
Richi5280
oklahoma
Yup took it to the the dealership and they said my diver side motor mount was busted! $100 to replace so not bad
BadDaddy2003
