Rear End Gear Change
Calicajun
Having a shop change out the rear end 3:08 to 3:73 gears. He is now on his fourth gear swap out as the first three sets of gears had a whine when driving. Today he said he going to put in another new set of 3:73 gears three cut instead of the five cut set he was installing.
Question, what is a three cut set of gears as to a five cut set of gears. Is one set of gears better than the other, stronger?
TheFuzz
Idiot Police
Spurbury, VT
You have 3.08 gears stock, so is it safe to assume that you've got a six speed trans? If so, why are you going w/ 3.73s? I think that with the six speeds, 3.42 is more than enough to really get it scooting while still keeping some semblance of economy in high gear. 3.73's in a six speed is the equivalent of 4.10 or better in a four speed.
"Becuase f*** you, that's why" is a perfectly acceptable answer, I'm just curious why you chose that ratio.
As to the cut, I'm not familiar enough w/ gears to have a clue what he's talking about. Pinion gear cut, maybe? Do you know what brand of gears he's using? If he's on the fourth set, there are some serious red flags flying. He either doesn't know WTF he's doing, or he's using shit parts. There's no reason why a competent tech shouldn't be able to get it right after three attempts.
C
Calicajun
Tried 3:42 gears and didn't seem to help with towing our 28' 5,800 lbs travel trailer. So when the shop couldn't get the whine out and said he was going to put a new set of gears in I up the gears to the 3:73. Hoping the 3:73 gears and the 6 speed trans will handle the load better with less strain on the engine.
Dave01
I'm surprised you need the 3.73 for that load, but they should pull very well. The tradeoff will be highway rpm that are very high if you drive 70 plus and some loss of mpg. Are you running stock tire size? If your tires are at all oversized it might explain the need for the gear swap.
I think the different cut numbers refer to gear profile, not sure if it's tooth depth or angle. I know the setup is different for the different cuts, and if I had to guess I'd say your guy isn't setting up the gear clearance correctly. Guys who do differential gears have a knack for it, and you want to go to a shop that does hundreds of gear swaps so they get the setup done right.
jdpber
GOLD MEMBER
The America
remember with a camper it is not so much the physical weight it is the drag that the hugh freaking box creates. It's dragging a wall and an anchor. The weight is relevant it is the non existent aerodynamics and horrible turbulent drag created that generates the strain. Makes 5,500 feel like 8k+
I pull a 20' and know all about the drag. Camper drag and windage sucks.
Dave01
Definitely a big factor, I guess a lot depends on whether you are towing at 55-60 or trying to push it up to 70, that wind drag really becomes the major issue.
Those 35's really look nice on your rig! Without doing the math, I'm assuming you've got 3.73's, but with those tires you must be equivalent to more like 3.42 or less. Or did you do a 4.10 swap?
C
Calicajun
I'm running 17" tires on the Tahoe and tow at speeds between 55-65 only. The shop is one of the highest rated drive line shop in the LA county, he has done custom work for a number of big name race drivers. Maybe that is my problem, I'm not a big name.
Dave01
No, sounds like the right place to be! Also glad to hear that they are willing to work at it to get things right.
Your 17" tires - what exactly are the sizes, 265/75-17 for example? Then we can see if they are stock diameter or not.
C
Calicajun
The tires are suppose to be stock 265/75-17 I think but will have to check them when I get the Tahoe back later today (I hope). Need to make sure of the tire size before I buy some snow chains for our trip to Klamath Falls, OR.
jdpber
GOLD MEMBER
The America
To clarify something that drives me insane (seller of wheels and tires) you have 17" WHEELS
Tires are rubber.
Wheels/rims are metal or wood.
C
Calicajun
Tires are rubber.
:hmm:lol The tires are 17", I have never measured the rims, just assumed they were 17" also. Tires are the rubber inflatable part, the rim is metal and together they make the wheel assembly. At least that the way I have always understood it. :signs8:
jdpber
GOLD MEMBER
The America
So your entire wheel assembly is 17" those are tiny wheels. Rim bust be a 13". Are you running wire Dayton's?
Tire = rubber = larger than wheel
Wheel/rim = metal = smaller than tire.
C
Calicajun
Well you know what they say about people that assume. That's why I don't work at a tire shop, I just support them more often than I like.:happy3:
BTW, any suggestions on snow chains, seeing you work with tires you have probably seen some bad results from using the wrong type of snow chains.
C
Calicajun
Just an update on the rear end gear change. After the shop tried six different set of gears, one 3:42 and five 3:73 sets, on the seventh tried I had them reinstalled the original gears. The Tahoe is again running nice and quiet. Did get the second radiator installed along with the oil cooler lines. So the Tahoe now has a large trans cooler, oil cooler, large radiator, rear air bags and a K&N air filter. Just wish I had time to use the Hyper Tech programmer before we leave on our trip towing the trailer.
TheFuzz
Idiot Police
Spurbury, VT
Too bad about the gears. I know that those guys sound like they know what's up...but seriously, six sets of gears and none of them were right? I'd try a different shop bro. lol
Goodinblack
I Like Tacos
Dirty South
What do you mean when you talk about the cut?
Six?
Ask him what pinion depth and backlash mean....... lol
All sets are cut to a certain spec. Name brand sets are relatively quiet...... unless shimmed wrong.
Mighty Hd
Florida
Specs on the vehicle? Year, etc?
How about a report? Fuel mileage NOT towing, in town/hwy driving? How was drivability improved?
I am VERY intrested!
C
Calicajun
My Tahoe is a 2013 with the 5.3 V8, it came with the lowest of the three towing packages (bought it used with 19,000 miles on it but the dealer lied about the tow package). The lowest towing package comes without a transmission cooler, oil cooler, heavy duty rear springs and only 3:08 gears in the rear end. I added a external transmission cooler and rear air bags, both work great. The transmission never gets over 193 degrees and that was towing a 6,000lbs travel trailer up I-5 Grapevine pass, all other towing the transmission temperature never went over 153 degrees. The gas mileage with the 3:08 gears was 22 mpg hwy (I drive easy), using the same route from Lancaster, CA to Barstow, CA with the 3:42 gear installed the mpg was 24. Never tested the Tahoe with the 3:73 gears installed as they weren't working right from the first test drive around the block. I still plan on putting 3:42 gears in the Tahoe as soon as I can find a shop that can do it correctly. I have to admit that the Tahoe with the 3:08 gears did a very good job towing the travel trailer from our house up to my sons house in Oregon. The average mpg towing was only 9.1 but then again that was with the wrong gears and too much trailer. We plan on moving down to a smaller trailer (trailer size is a whole other story) and 3:42 gears to help improve both mpg and towing ease.
Hope this helps, please feel free to ask anything I may have not covered.
Mighty Hd
Florida
My 2013 Z71 4x4 tahoe with 3.42 gears (tow package) running 275/65-18 tires feels like a slug.
I'm barely able to break 12mpg in the city during the summer months running standard 10% blended pump gas. If I run ethanol-free fuel I can get 14.
In theory, the larger tires reduced the final drive ratio to about a 3.08-ish if I remember correctly.
Towing an empty uhaul enclosed trailer up I-75 was horrible, hunting gears and I REALLY had to get into the throttle to pass someone.
I plan to re-gear to 3.73 if I end up keeping this thing. As I said, it is a slug and feels like I've got 20k behind me all the time. Horrible. My 08 and 11 tahoes were never like this and they were ordered and built exactly like this one.
C
Calicajun
Just noticed I didn't state the in city driving mpg which for me is 15.5 to 16 mpg doing all stop and go city driving. Going to work which is a straight 12.5 mile drive with only a couple of stops mixed with city driving I get around 17 to 18 mpg.
HeavyHoe03
