Hoe pulls to the right when braking.
Green monster
Toronto, Canada
Well driving to work tonight and had to slam the brakes due to an idiot in a Honda cut me off, the Hoe pulled really hard to the right when on the brakes. I didn't think much of it at that moment but now every time i brake the truck is pulling to the right. In the summer I replaced all the brakes( rotors, pads, rear shoes and calipers). Has this happened to anybody else? I'm thinking the sliders might be sticking but would love some input.
zomeizter
North AL
Been there, seized sliders, on another occasion, I had to slam on brakes too and one of my calipers failed, cylinder got cocked in the caliper.
Donnie Yukonie
Yates Caretaker
Could be the Sliders , However when this happened to me I found it to be a stuck caliper . how does your brake fluid look?
Asfalto
Northern Italy
maybe just silliness.. when it heppened to me it was just the front rh tire a little underinflated.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
assuming tires are inflated correctly, either your left brake lines are clogged or either the left front or rear brake assembly is jammed in the released position.
GotExhaust.com
Senior Member
Probably brake related but a good time to check your wheel bearings and ball joints for play.
Green monster
Green monster
Toronto, Canada
Well finally got to work on the Hoe today and the sliders were seized on the driver side caliper. Pulled them out, cleaned them up and lubed. The Hoe is back to normal :) Thanks guys
I know this is off topic but gotta replace the cats on the Hoe so thinking of doing a full exhaust. 2.5" manifold back into a single muffler and 3" tailpipe. Has anybody run a Flo-Pro Max muffler?
Durobans
