Wheel hub assembly replacement
franksbanks
Arizona
Going to replace my wheel hub assemblies this weekend- my Yukon is making a horrendous noise while driving due to the bearings being really bad-
Got a pair of hub assemblies from Ebay yesterday- 110$ (pretty good price compared to autozoo)
I’m going to pick up all the additional tools in which I will need: need some verification that my list is correct:
T55 socket -brake calipers bolt
36mm socket-CV axle nut
Will I need to get a ball joint separator tool?
Misc specs needed:
What are the torque specs to re tighten the bolts afterward?
Feedback is appreciated
To answer your question about the ball joint separator tool you should NOT need to touch your ball joints to replace your hub so no worries :waytogo:
What brand hub assembly did you end up getting?
franksbanks
franksbanks
Arizona
thanks for the quick response-
for some reason i was thinking the ball joint would get in the way- (ill have to replace them soon too)
here are the specs ont he hubs-
**Detroit Axle ** Complete Wheel Hub & Bearing Assembly
http://www.ebay.com/itm/17094840480...X:IT&_trksid=p3984.m1497.l2649#ht_2650wt_1170
I've not heard of that brand. I hope they work out for you! They are definitely well priced and at least worth the shot :waytogo:
In order to replace the hub you should only have to removed the wheel, brake caliper and rotor to gain access to the hub so no removal of ball joint is required. It's a fairly straight forward job. Get a BFH (big friggin hammer) ready, though, as you may need it to break the hub assembly lose once you have the bolts out :)
franksbanks
franksbanks
Arizona
I hope they last me for a few years- the previous owner(s) did not perform any maintenance on it... so now i have to replace all the worn parts out- which in return, will make it a more reliable truck- and thanks to the members on this site ( like 07Burb ), it has made it easier to get it done :worship:
Get a BFH (big friggin hammer) haha in deed :cheers:
Gzes
the drifting 2dr
Wichita tx
Detroit axle is a good brand. Did my hubs on the exploder with that brand. I would do ball joints aswell since your already in there
franksbanks
franksbanks
Arizona
That’s good to know- I was a bit concerned about them, but I figured I would take the risk and test it out. If they did fail I wouldn’t mind replacing them again, as long as its not within the first year.. then I would be mad.. lol
I would do the ball joints, but it’s too late for them to get here in time-I like to save money by buying items on ebay & amazon- so I’m going to prioritize the hubs first- I don’t want to get stranded if the wheels lock up you know what I mean
I plan to order the upper/lower ball joints next week along with a replacement set of the idler arm & pitman
I’ll let you guys know how it goes once im done-
Gzes
the drifting 2dr
Wichita tx
Ok yea when I was doing mine saw he had ball joints and said eff it went to the store got em and used my shop discount and did em
livingez_123
Sandy, OR
its best to break the axle nut loose with the truck still on the ground. you also have to remove the caliper bracket.
imi4tth3w
the caliper slide bolts should be a big torx head bolt and then the caliper bracket bolts are 18mm.
X2 on breaking the axle nut loose while the vehicle is on the ground. I made that mistake once and never again lol
franksbanks
franksbanks
Arizona
This means I will need to go through the rim center right? I don't think my rims have enough gap to pass a 36mm socket :banghead:
---------- Post added at 10:55 PM ---------- Previous post was at 10:54 PM ----------
Thanks for the info. I'm taking notes . :drink_nl:
---------- Post added at 10:58 PM ---------- Previous post was at 10:55 PM ----------
See this is why I like to ask the questions first , there's no worse feeling than being stuck on something that could be done right off the bat
electro
Kitchener, ON, CAN
I did mine recently, and I bought a 3 jaw puller to push the hub assembly back of the steering knuckle.
Axle nut really isnt all that tight, I cant recall torque spec. But as stated above your best cracking it loose with tire still on ground.
You will need wrench to loosen hub to knuckle bolts as there isnt the clearance for sockets. Ez job.
the axle nut will pull the hub back into the steering knuckle and then of course torque everything to proper specs.
605Jake123
Sioux Falls, SD
I am also planning on changing out one of mine this weekend. Does anyone know what the proper torque specs are for the axel bolt and hub bolts?
franksbanks
franksbanks
Arizona
thanks for the info
i picked up a 3 jaw puller today and a set of hand wrenches
ive been looking for the torque specs and found it using a google search
Tighten the wheel bearing mounting bolts with a 3/8-inch drive ratchet and socket, along with a 6-inch extension only until they are snug. Remove the extension and socket from the ratchet and install them onto a 3/8-inch drive torque wrench. Tighten the wheel bearing mounting bolts completely to 133-foot-pounds of torque. Install the spindle nut onto the end of the axle, and tighten the nut to 106-foot-pounds of torque using a 3/8-inch drive torque wrench and socket. Connect the electrical wiring connectors together by simply pushing them together with you hands.
Read more: http://www.ehow.com/how_7871815_replace-2003-denali-wheel-hub.html#ixzz2k5cJfCx3
Rd05lly
Auxvasse MO
You could take wheel off and hold brake down to break it loose if you had too.
franksbanks
franksbanks
Arizona
That's exactly what I did.
Question though. I noticed there is a ground cable showing near my left shock. Anyone seen this?
(See attachments)
varminpoolteam
