Installed RC Leveling Kit and now a knock when I turn the wheel...
babamerino
Honolulu, Hawaii
Hey all… I installed my RC 2" Leveling Kit and now I have a knock and lock sometimes when I turn… I know I need an alignment but was wondering if this will be solved by that or if its a bigger problem… Thanks in advance!!!
mfdrookie516
Loading.......
How did you install it? I don't have any abnormalities from mine. Just curious if maybe you left something a little loose? I did have to go back in about a week after installing and tighten my ball joints back up. Somehow they loosened up and I started getting a bad vibration. Torqued them back and have been good since.
babamerino
babamerino
Honolulu, Hawaii
Maybe something's loose??? I'll go check the bolts again... It only knocks when I'm turning... Thanks!!!
Neil Layne
Steel Neil
Lafayette, Louisiana
sorry i missed this. mine does the exact same this when i am at full lock. I'm pretty sure that it is normal. i have had no problems from it at all.
mfdrookie516
Loading.......
I make it a point now to go in and check every oil change when I grease.
Neil Layne
Steel Neil
well poop. haha, i need to go get that all tightened. i had it checked by a guy and he said it was normal. ill have to go fuss at him now.
dizhai
