Bilstein 4600 or 5100???
08stockhoe
Which ride better with. Belltech 4" rear drop.
shundal
NorCal
I'm running the Bilstein 5100 shocks with a 3 inch drop and am very happy with them. They dampen very well, and provide a nice planted feel to rear end.
08stockhoe
08stockhoe
Have you tried any other series of bilstein? I was kinda set on the 4600 but now I don't know. I didnt even know about the 5125. I want the best ride I can get in rear and bilstein seem like the way to go. But now you've thrown me a curve ball.
shundal
NorCal
I've ridden in a Tahoe with the 4600 shocks and they ride great, but were a little too soft for my liking. I like a little more firm ride but still not harsh and The 5100s offer that. Most people use the 4600s on here though. I don't see many using the 5100
Danzigman
Galveston, TX
5125 is for raised vehicles I think. What is the difference between the 5100 and the 4600?
08stockhoe
08stockhoe
I would guess stiffer. Everybody says they're using bilsteins but not sure what series, Besides shudal.
shundal
NorCal
Your correct, the 5125 are designed for lifted applications. However, my shocks were ordered to be shorter to work with my rear drop. I went with the 5125 after a member on here (Modded) had good things to say about them, and I rode in a tahoe with the same setup. However, on here, people go with the Bilstein 4600 as they are a direct fit for the stock tahoe.
shundal
NorCal
Are 5100's not a direct fit?
No, they require a slightly smaller bolt size. I ended up just pressing out the bushings from my old shocks and using those, so I could keep the factory bolts.
Danzigman
Galveston, TX
I just ordered a set of 4600's for the front of mine. They will be replacing the stock red shocks. I have almost 70k on the clock so I guess it is about time to replace them. I have the nivomat ZW7 premium ride shocks in the rear. Anyone know how long these things last?
2006Tahoe2WD
Silicon Valley
How did this turn out for you?
I'm considering the Bilstein 199021 springs and 4600 Bilstein shock set.
Rear 24-143806
Front 24-065009
ulakovic22
Argyle, TX
4600's here, they ride great and control everything just fine, but they are a little soft for my liking as well.
2006Tahoe2WD
Silicon Valley
Anthony,
Thanks for the note. I'm still thinking the 4600 series. I'm old and want a smooth quiet ride. I have a sports car with Bilstein sport - so if I want a bumpy ride I have that available to me.
My current question is when changing out of the ZW7 RPO (Premium Ride) to "standard" shocks why not just get stock springs from GM? They don't cost that much, maybe less than the Bilstein (1999021) or Eibach (pn not known) springs.
pilot62000
Orlando, FL
How do you transfer the spring perch from the OEM strut/shock to the new Beilstein 4600 shock to form a complete strut assembly to reinstall? Thanks.
bacin87
San Francisco, Ca
Rear 24-143806
Front 24-065009
I am replacing everything and wanted to know are the Bilstein 199021 springs for autoride or for stock springs? I dont have a autoride on my truck and want to buy the correct item.
ATIII
Brighton, CO (Denver)
I assume your talking about a front coil over? If so I took a set from my buddy's Trailblazer to a local shop and they loaded them for $50.
JasonW4141
