How do I make my 2007 Tahoe 4x4 ride better on washboard roads?
mikesmith
Well, I couldn't get any responses over on TahoeForum.com, so let's give it a try here.... :)
I have a 2007 Tahoe LT 4x4. I just got it and got a great price, but I'm very disappointed with the ride quality. I could deal with it if I spent all my time on pavement, but the problem is that I work in real estate in an area with a lot of dirt roads and spend a lot of time driving on washboard and just generally bumpy roads, often with clients in the vehicle. Right now I have to go pretty slow to avoid a very uncomfortable experience for the passengers. A lot of the problem seems to be in the back. For example, when I hit a speed hump at 40 mph (the speed at which my old Honda Accord goes over that same hump quite nicely) the front handles it fine but the back end pops up in the air pretty hard.
What can I do to improve the ride quality on these roads? I have searched the Internet for hours but can't find much useful information. I have thought of a lot of possibilities and would like opinions.
1. just change the shocks... to what? I saw the conversations about Bilstein vs. Monroe, etc. but I never saw anybody talking about what works better for bad dirt roads...
2. change the rear springs... to what? Does anybody make a softer spring that could be supplemented with an air bag system? Would Z71 springs be better or worse?
3. Can the GM autoride system or auto-leveling system be easily retrofitted to my vehicle? Would a vehicle thus-equipped handle these rough roads better? Since I got a good deal on the vehicle I might consider spending some money on this if it would work...
4. I intend to level the vehicle and swap larger tires at some point in the future. Icon Vehicle Dynamics, King, etc. offer front coilover replacement units (that can be paired with their shocks for the back) that are pretty expensive... does anybody know if they are worth the money? I can't find any reviews of these products. The marketing always mentions "great ride" but that could mean anything. If they are designed from a desert racing perspective (take big hard hits without bottoming out) then I'm not sure if they would satisfy my need to go reasonably fast down a regularly graded road that is littered with pothole-size holes after the 1st rain storm (did I mention I live in Florida?)... or would they? My local 4x4 shop doesn't have a clue beyond putting lift kits on SuperDuty trucks.
Any thoughts are appreciated! I'm very perplexed at the absence of people with the same need as me... is everybody just putting up with the "truck ride" because it's a truck?
My understanding of why "trucks ride like trucks" is that the manufacturers are forced to compromise between ride quality and load capacity with their suspension design. They have to compete for trailer weight ratings, GVWR ratings, etc. but the higher the load capacity the stiffer the spring. That's why most pickup trucks bounce horribly in the rear when driven empty.
(side note--it's good to see that Dodge is leading the way in improving this problem. All their trucks for 2014 have air bag-supplemented suspensions as an option.)
I want to modify/tune the suspension to ride comfortably when mostly empty (1-2 passengers most of the time) and then add something (probably air bags) that can be used to stiffen the spring rate when I need to hook up a trailer and carry more weight in the back.
The main thing I'm not clear about is if my problem is finding the right shocks, or if I need to address the spring rate as well.
Thanks!
(Sorry for the long post--it's a combination of a previous initial and follow-up post)
M
mikesmith
Correct--no air suspension.
I haven't tried to figure out if the shocks are worn out, but isn't the sign of worn-out shocks a mushy ride and not a stiff ride? I'm assuming my complaints are due more to spring rates (the load-capacity issue) but I'm open to being educated...
My tire pressure is at the factory recommendation on the door sticker--I think 30 psi?
yates ™
Resident Apple hater
Iowa
A shock can fail either way, it can become a "squishy" ride or it can also freeze in the extended position (another member just had this problem). I would start with checking shocks and go from there.
M
mikesmith
Cool, good to know--I figure I'll definitely be changing the shocks regardless, but I'm hoping somebody can guide me to the right shock solution for my needs. I know some shocks are tuned for handling, which I think would mean a stiffer ride which would be acceptable for paved roads but the opposite of what I need. I don't drive aggressively and would gladly trade handling for ride comfort.
M
mikesmith
For what it's worth, I hooked up a trailer with a little weight to the Tahoe this weekend for the first time. It was enough weight to sink the rear enough to basically level it out. It definitely settled down the rear suspension... I'm still wondering if anybody has ever tried swapping in softer rear springs augmented by air bags on a Tahoe or Suburban.
Xshooterx
I hear all of the lowering fans talk about Belltech springs being soft and rendering a cushy ride. Do they make a prong to maintain stock ride height?
Coupled with bags to supplement for heavy loads...could that be a solution? Or at least something similar.
M
mikesmith
Yeah, could be... I'm just hoping that I'm not the only person with this request and there is a product out there I haven't found that addresses my issues... seems like it would be pretty simple to make a softer spring that maintains stock ride height without needing some kind of spacer, but maybe that's an option.
I'll probably make some phone calls to some suspension companies and see if they have any helpful info.
TheFuzz
Idiot Police
Spurbury, VT
Coming from the world of Land Cruisers, I know that many people who built up their trucks for overland expedition and washboard roads were VERY happy with Kings, as far as shocks go...but in our case that's only half the battle.
The only real way to change the dynamic of the ride is to swap out the springs and the shocks. Leaving the springs stock isn't ideal, but new shocks will offer some improvement (as long as you don't cheap out on them). The problem in our case is that there aren't exactly a plethora of rear spring options for the GMT900 platform (read: NONE) due to the fact that they just aren't chosen for hardcore off road applications all that often - most lift kits just involve spacers, shock relocation brackets and other bolt-on lift solutions to be used in conjunction with the OEM springs (lets face it, most lifts for these trucks are cosmetic, not performance oriented).
So, you're in the same boat I am. I travel dirt roads mostly when heading off to camp or to get off the beaten path with my family. The most cost effective solution I can find is the Bilstien 5125 racing series single-tube shocks (about $400 front and rear), rough country front leveling kit, and daystar 3/4" rear coil spacers. It's not ideal for washboard, but my research leads me to believe that it will help pretty dramatically. Getting new springs would round out the package nicely, but it's just not in the cards unless you want to pay a custom shop to whip you up a one-off set of springs...and that's a costly option that I'm not willing to pursue.
King shocks would perform light years better than the Bilstiens, but at $2200+ a set, they are out of my price range.
M
mikesmith
Yeah, even the products from Icon and King that I saw only replace the front springs/struts (claiming to add a little travel) but left the rear springs alone and just offer shocks to swap out.
I asked Pure Performance about Tahoe products. Until recently they were showing some pretty nice (and quite expensive!) 6" lift products on their web page that advertised longer travel, better ride, etc. including new rear springs. They took a lot off the web page temporarily, but they told me they are working on a 3" lift long(er?) travel system for the Tahoe that includes longer travel progressive springs for the rear. It sounds like exactly what I'm looking for... I'm just scared about the price! :)
TheFuzz
Idiot Police
Spurbury, VT
That sounds promising, but I'd be scared of the price too! Maybe they'll sell just the springs eventually. That would at least be a start.
I'll hopefully be picking up the Bilstein 5125s here in a month or so, and once I get them swapped out I'll let you know how the ride is. Washboard is a tough nut to crack from a comfort standpoint though - you almost have to have a shock with preset valving and highly adjustable dampening. King would be the way to go in that regard, but I work on a cop's salary...I don't have 3K to invest! :anitoof:
TheFuzz
Idiot Police
Spurbury, VT
Him? Probably nothing. He wants to revamp his whole suspension.
The rest of us who like options? Anything we want. Nobody else even makes decent lift springs for these trucks, unless you want a gaudy 6" lift. So like I said, it would at least be a start. Eventually I would like to see 1" and 2" lift spring options with better spring rates than the OEM variety, for those of us who don't want to go much higher than a leveling kit but still want a better off road ride.
yates ™
Iowa
There is not really much of a market for it though, most people that want a small lift are only doing so because of the cost factor.
TheFuzz
Idiot Police
Spurbury, VT
That's been my point the whole time - there's no market for it. I'm trying to provide ideas for him that don't cost an arm and a leg. Guys like him and me who want good performance out of only a minimal lift are the minority. He's trying to come up w/ solutions that don't involve a huge lift because he's going to be driving clients around. I don't want a huge lift either because 1) I think it looks like ass on these trucks and 2) I have a pregnant wife and two little kids that don't want to have to use a ladder to get into the truck.
Lift components that come in the 2-3" range are rare and expensive. I'm trying to make due with factory springs and decent shocks, but to truly solve the issue of good handling on washboard roads, it costs much more money than I'm willing to part with right now.
M
mikesmith
The weird thing is that you would think there would be a big market for anything that helps these truck-like vehicles ride better. Most get driven with 1 person most of the time with no weight to justify the spring rates in the rear. Same goes for most pickup trucks. I think there's a good trend developing for the pickups of offering softer springs paired with airbags (note that all 2014 Ram models including heavy duty versions will offer that from the factory). GM has the factory options for the SUVs but there are a lot out there on the road that don't have it, and the ones that have it complain about it breaking.
Think about all the people driving long distance on dirt roads outside the urban areas in the Midwest, West, etc. Who wouldn't want to be able to go faster?
Of course, I'm open to being told I'm wrong in thinking the engineering is that simple... :)
Zed 71
Pacific NW
I believe the 5125s are just universal fit versions of the 5100s. IMO it would be better to get the 5100 because they would be valved specifically for the Tahoe.
You guys are right though, a custom tuned spring and associated shock would be optimal.
Good luck and keep us updated.
wbreaux
You should probably just do a quick little prerunner build on it
08grey
Try test driving a 2013 on one of these roads. Tell the dealer you want to specifically ride a washboard road. This will give you an idea of where your current suspension stands vs new oem.
Sent from my iPhone using Tapatalk 2
MoundMedic7
