Leds for License Plate Light
mmeachem
Do you guys think these will fit in the license plate light
or these
Screwd up 6
1st ones wont fit. 2nd ones are pretty close on the ones I had.
mmeachem
mmeachem
Screwd up 6
When I used the 2nd ones, they were pushed all the way to the front of the lens cover...they might have been too long, but with force they made it lol. Not to say that its a good thing tho.
chauncey0337
MLT, WA
I had the second ones and had a tight fit. So tight I broke a trace on one bulb. Now I have ones very similar to the first ones and they're great. Just make sure the base is standard 194 size. And they lookbetter because all the light shines out the front and not wasted for the sides in a non reflective housing.
a4edwin
ny
thats how mine are.
mmeachem
mmeachem
Are you talking about one of these and which do you think will fit
Or
chauncey0337
MLT, WA
The flux leds you just posted may be too big. The other ones will probably work though. If I were you, I'd go with the first ones in the first post.
mmeachem
mmeachem
You think the 1st will fit the tag lights and will they fit the map and door lights
Also to replace the door lights do you have to take the panel off or just the cover
chauncey0337
MLT, WA
Yes they'll work for tags and maps and doors. But I'd use bigger ones for the doors. I'll have to get you a pic later. To get to the door lights just get a small flathead and pry open from the red side.
mmeachem
mmeachem
Thanks Chauncey
Also will a 68 smd 3157 be brighter than stock?
And which of these bulbs will fit all the need locations (puddle&domes)
An 42mm 8smd 2 rows of 4
or
16 smd 4 rows of 4
chauncey0337
MLT, WA
I have these for maps, footwells, and doors-
I have these for tags-
But I want these for my doors-
For my puddles and domes I have ones similar to these. I wouldn't go bigger for puddles because it's a tight fit-
This is just what I have for my truck and not necessarily recommendations.
As for the 68 smd being brighter than stock... that all depends on the leds used to make the bulb.
josueh95
Or
i have these second ones in my doors and uder the dash where it lights up the floor and also on the two round dome lights on top..work great for me..also have those in my dash
let me see if i can get some pics for you right now
---------- Post added at 11:26 PM ---------- Previous post was at 10:56 PM ----------
mmeachem
mmeachem
will these fit the dome and puddles they are only 2mm wider than the ones Chauncey have
:banghead:
sorry if it seems that im asking the same thing over and over but i just want to try and order the same bulb for dome and puddles from the same seller
chauncey0337
MLT, WA
:banghead:
I'm pretty sure they will fit puddles and definitely domes. They actually look a little more narrow than he ones I have. How much they want for those?
Do you have a link to these by chance?
JeffK
