Turn signal blinking fast help
car.guy60
Berea, OH
my left turn signal blinks very fast (rt side is normal) all bulbs are new but when I hook up a trailer to pull the blinker works as it should. any ideas?
chauncey0337
MLT, WA
Welcome. I know you said all bulbs are new but are they all working, mainly turn signals? Usually they do this(hyper flash) when a signal bulb is out or diconnected.
anton28
Weird. That's the first sign of a bulb being out.
YUKON1999
what if they were leds would that matter because my rear are LED and they blink super fast too?
chauncey0337
MLT, WA
Leds draw very little power so the truck thinks the bulbs are out and will hyperflash. Unless the bulbs or housings have built in resistors to simulate the draw of a regular bulb.
08grey
It's almost what he said. The regular bulbs take a second to brighten. The positive pulse is actually the same rate it's just that the led lights instantly and reacts to the pulse while the incanndesant takes a second extra.
chauncey0337
MLT, WA
Yes the incandescent takes longer to react but the rest of your statement is not true. A blown or led bulb w/out resistor in the signal will cause the opposite signal(front or rear) on same side(left or right) to hyper flash.
briannorris
