seven9st surfer
Milton, FL
A good wash and wax. And finally upadted my sig with a picture
PVC valve
Evap purge solenoid
Roof rack reverse lights
Painted z71 center caps
And found a leak in the radiator plastic :/
View attachment 22045View attachment 22046
I am intrigued by this. Did you follow a guide, or do this on your own? What parts did you use, and how did you do it?
b4z
I have taken off the bug deflector, vent shades, body side moldings and fender flares off our '04 ' **. It hasn't been top bad, but the pinstripe is cracked and dried up and nobody in charleston has an eraser wheel.
liftedtahoez71
The Piaa fogs I'm going to mount in my roof rack rear caps came in over the weekend. Will also be painting front and rear roof rack caps gloss black to match truck. Just ordered my escalade smooth wiper cowl to do antenna delete. Will be trying an antenna mounted in between headliner and roof skin! Still tryin to decide on clear corners!
Claymationzoo
Maryland
I'm guessing your talking about the reverse lights? If so fell free to pm me an i can answer an questions
---------- Post added at 08:54 PM ---------- Previous post was at 08:52 PM ----------
The antenna delete when I did mine I just unscrewed the three bolts and laid the antenna down along the inner fender. Noticed some signal loss but still get clear HD radio channels and all the stations I used too. I mainly use a USB so wasn't that worried
Pachanga02
Ny
In the past few days I installed Tonys 3-5/6 kit, helper bags, 24s with new tires and just today got it aligned. Looks great and rides nice.
Pachanga02
Ny
Now and then pic. A little bit of a difference. Sorry need to get caps on. I'll have better pics when its nice out and gets washed.
Pachanga02
Ny
Thanks buttons. Ill post a pic of it with the torsion bars not adjusted, turned heads like crazy on the flatbed.
Alex33
I started it up and moved it 4 inches, lol. Needs tires for my wheels :(
seven9st surfer
Milton, FL
Replaced my faded/chipped factory fogs with new clear ones, replaced my faded/scratched rear wiper arm stop, and treated all the exterior black trim with 303 Aerospace. Might post pics of the new fogs when I get them aligned tonight. Went with yellow bulbs this time.
Edit: And did the roof rack crossbeam delete. Much cleaner looking now, IMO.
NjA4207
