Airbag Service Light
Goodinblack
I Like Tacos
Dirty South
Mine ended up being the entire curtain airbag in the roof.
Dealer fixed it because it had been in for the same problem like 6 times.
Marc_Rez
NJ
I dont want to have to give the dealer money if I can do it myself but it seems like I might have too
okfoz
Service Airbag message came up, and I thought I would give this a try. But, both of mine appeared to be plugged in... I gave them a little pull, but they were stuck.
okfoz
Long story short, my daughter's car was in a bump shop that I have do all of my work, so I called and asked what the code could be, he said chances are it is one of the front sensors under the radiator core support... Sure enough, they let me borrow the scan tool and it came up as B0086 "Front impact sensor internal fault" So I bought a pair of new ones. I got the Dorman, I hope they work.
$60 each on Amazon. + Free shipping
okfoz
Update, After crawling under the front of the truck, removing the 4 15mm bolts from the plastic brush guard, and then the 2 10mm bolts (1 each sensor) from the sensors, it took me all of 20 min... Easy job, problem went away after first start...
gtp1500
I had the service airbag message and found the seat belt pre tensioner...? was unplugged.
The pillar cover behind the passenger seat has a rib inside and it had pushed the release clip and unplugged it.
dizhai
