just dropped my tahoe bad toe out
johnnyt5646
i just dropped my tahoe 3/5 and my steering drifts from left to right. i noticed that my tires are toed out. is this common on a drop. just want to make sure i didnt also mess anything else up.
You didn't get an alignment after the drop?
J
johnnyt5646
no i just finished it tonight. it goes to the alignment shop tomorrow. just wan to make sure that this is normal and can be fixed by an alignment shop.
It's normal to need an alignment badly after a drop. After they are done it should be back to normal and without the toe.
lowAZhoe
Resident GM Tech
Phoenix, AZ
it is normal after a drop. but i do believe the djm instructions for the 3" drop lower control arms say 3 turns in on the tie rod ends will get you close.
magicbus
Wichita Falls, TX
You are killing your tires if you are driving it without adjusting the toe. I would have it towed to the alignment shop. This is why I had an alignment shop install my arms.
noJeepshere
Bountyfull, Utahrd
The couple miles to the closest alignment shop won't hurt. Going on a 20 mile test drive will.
cent frum a smaert fone
varminpoolteam
