Custom box I had built for the Yukon!!!!
jmax313
My man Kerry over at 5k mobile built me a box that go in between the captain seats it holds a 10" sundown sub tell me what u guys think....
Sent from my SPH-L710 using Tapatalk 2
---------- Post added at 01:28 PM ---------- Previous post was at 01:26 PM ----------
I'll have more pics once I get home
Looks pretty good :waytogo: The only improvement I can see is the addition of cupholders on top to make it more useful to passengers but otherwise looks good :)
Also, how do people get to the third row with that box there?
jmax313
jmax313
The seat still goes up plus the box is sturdy enough to stand on
jmax313
jmax313
Looks Awesome! How does it sound?
It sounds better than I thought it would... Now that I'm a lil older I feel like I don't need to shake windows no more so this is perfect for me and I didn't lose any space
Phantom240
Needs an aero/flared port, but otherwise, excellent work. Must have take forever to kerf that plywood. Also, is that an SA or an SD?
jmax313
jmax313
Its a sa but he said I can switch to a SD... Far as the port I'm lost on that
EMF Audio
Spartanburg, SC
I kinda wonder on that port. It's not smooth on the inside and not real solid. I think going another route might sound better, even if it sounds good now.
Phantom240
LOL
That's one way to do it, I suppose. That port is DEFINITELY sketchy as f*ck.
An aero port is a port where both ends have a parabolic flare. It helps reduce noise and increases volume a slight amount.
...and didn't you say you had a shop build you that box? Are they an audio shop or ?
NathanJax
Vacation Nathan
Jax, Fl
yeah that port isn't really doing much but moving around inside the box. If I were you I'd take some of the same size PVC pipe and make it look identical to the other stuff...
vsaravia
