Aftermarket radio problems...
rolfsent
Cincinnati
So my original radio in my 97 Yukon decided that it didn't want to play cassettes anymore and that's a problem for my XM. So I installed a pioneer head unit I had laying around and all was great. I had my XM running through the AUX and had not a single problem. Now today my rear door speakers are no longer working, and they were working for the last week. I thought maybe I blew the rear door speakers so tried the original radio and the rear door speakers came on fine. I checked the wiring harness on the Pioneer and I can't find a problem, they are all soldered and heat shrink tubed. Any ideas what could have caused them to stop working? Also I have no idea if the back roof 4x10's are working because they were both blown and I couldn't stand the way they sounded so I removed them.
rolfsent
rolfsent
Cincinnati
check the fuse for aux power.
I actually figured out that the remote/power ant wire was coming loose so fixed that and now I have an even bigger problem. As I was putting the pioneer back in the dash the radio cut off and wasn't even lighting up. So I thought maybe a fuse blew. I checked all the fuses in the car and the one on the radio and they were all good. Now I can't even get the stock radio to work. When I turn the headlights on the radio lights come on but nothing on the little screen, the only thing that will happen is the time will pop up for a second if it hit recall. Any ideas now????
SunlitComet
OBS Jedi-Do Good
unknown at this time.
a loose or broken main power or ignition switch trigger wire going to the head unit. take the unit back out and inspect it all and any terminals or splices on them.
rolfsent
rolfsent
Cincinnati
The pioneer cut off and went completely black and I couldn't get it to come back on when I was sliding it into position. I also tried the original radio and now it no longer works. It will backlight when I turn the headlights on but that is it. I really can't figure out what is going on. All fuses are good.
rolfsent
rolfsent
Cincinnati
So I have not been able to find a a problem with any of the wires. Is there anything else that could be wrong?
rolfsent
rolfsent
Cincinnati
what exactly was the name off that wire you hooked up and what was it hooked to?
Not sure what you mean. I had a Pioneer HU that I was installing and it had the plug and play harness to fit the old radio harness and the antenna adapter.
---------- Post added at 05:16 PM ---------- Previous post was at 05:13 PM ----------
Unless you mean the blue wire on the HU to the harness that powers the factory amp for the rear speakers.
rolfsent
rolfsent
Cincinnati
yes and it was after you hooked up that wire that the radio stopped working entirely?
It worked until I slid the radio back into place. I tried the radio before I slid it back in dash and it was working fine. Something happend as the radio was sliding back into place, the whole thing just went black and the sound stopped. Now the Pioneer nor the oem radio work when hooked up.
Buford bubba
