Who has the highest miles thread.
JKmotorsports
Austin, TX
Now at 176k and still climbing. Other than my drivetrain being beaten up by the s/c, only things I've had to replace so far is water pump, fuel pump, and couple ball joints.
Hogan
Hogan
I have a 2000 Tahoe with 374,773 miles. Running well....drive it every day to work....120 miles roundtrip. Hoping to get a half mil out of it.
Hogan
Type of oil....
Nothing other than regular oil, not using synthetic or any special type of high mileage oil. Within last 30 K miles, am losing about a quart every 5K miles.
MarqieMark1
LaVergne, TN.
2000 1500 XL 206,417 on mine. Runs/Drives very well for a 13 year old truck. Using Valvoline 50/50 Synthetic now. Was getting only about 2200 miles outta conventional oil, afterward, it would look black..the higher mileage Valvoline oils hold up better.
dcwhybrew
I've got 125,500 miles on my 06 Yukon, which seems low compared to most. I bought it in August 2012. I've been using synthetic Mobil 1 5w30, K&N 2006 filters, M1 synthetic gear
oil in the diffs, Nd the synthetic BG products in transmission and transfer case (because I can't find synthetic m1 products for those two).
99'Hoe
Miami, Fl
1999 Tahoe 4x4 4 door. get ready. this will be a LONG list for a Verry abused Truck.
I got her for free with 160,000 miles 11 months ago and this is what ive done so far.
spark plug wires
EGR Delete
Engine temp sensor
Silverado rims
BF Goodrich Mud terrains
oil pressure sensor
subwoofers
under hood light
trailer lighting harness
rear break drums
rear wheel cylinder
rear seats folding mechanism
Fog light install
second battery install
:::(now for the blown engine part 1)::: ** Blew the Head Gaskets ** 175,000
Head Gaskets Job including Machined Heads
:::(now for the blown engine part 2)::: ** Blew Cylinder #2 connector rod bearing ** 180,000
connector rod Bearings
Main Bearings
timing set
high pressure oil pump
Machined Crankshaft
Rebuilt Rear diff, (She Was Chewed to Pieces)
New Steering Column
Rear wiper motor
A/c blower
fuel pump
a/c Leak fix
rear Drive shaft U Joints
transfer case seal to stop a leak
drivers door hinge pins
level front suspension
idler pulley
belt tensioner
belt tensioner pulley
spark plugs
interior door handles front
new interior Light bulbs
new distributor with rotor and cap, (( torque overload made the Camshaft gear completely tear up the gear on the distributor. had metal chunks in my oil pan.))
new hardware for rear break drums
lower temp thermostat so the engine runs a bit cooler.
new Belt
And thats honestly all i can remember for now... i STILL have to
change out the Rear interior door handles
new hood, Gloss black paint job
lift kit
HID's
New shocks
suspension work front and rear
alignment
A/C compressor
and now i Have to Rebuild my transmission because i lost 4th gear on my way back from naples the other day.....
And at 22,000 miles later, 11 months. she's at 182,000 miles.. still chugging along... :) shes been more than a headache then you could possibly imagine. but she's still my classic baby and i will continue in my endeavors to restore her :)
SO TELL ME, What have YOU done to your baby lately? cause i know ive been VERY Busy :)
Blakesdad
2005 Tahoe, I'm going to turn 350k in less than a week. Need to change my instrument panel sooner than later.. Water pump was replaced at 240k. My 4x4 control module had to be changed at 200K.. other than that, no real complaints and happy as a pig in "s"
fuzzyimage
Pushing 220k on my 02 and only a water pump, an AC blend door actuator, and starter to speak of. Otherwise, vehicle is "Tip Top"
Cscottsss
Wow, this is good to hear. Just bought my 04 Z71 Tahoe with 150k. Hopefully I can get another 100k out of her.
PB1
I have 182,500 on my 01 hoe. I have did the usual like breaks, and tune ups. Original transmission and honestly it still runs like a champ, most of the time...
Sent from my ADR6400L using Tapatalk 2
*Update*
I have rolled over 11k in eight months. I'm sure to go over 200k this year. But due to sequestration, I'll have her a few more years.
Sent from my HTC6435LVW using Tapatalk 2
Jdeshler
Alabama
384,000 miles on ol roxanne!! i win lol
kschumake83
Orefield, PA
2002 Tahoe has 115000 so its just a baby. My 2000 Silverado is waiting for a trans at 190000 but I do things with that truck that make the duramax crew cringe. I pulled a front discharge concrete truck out of the mud, in 4low the truck was hopping off the ground. Also I pretty regularly pulled an 8000 lb trailer and skid steer combo. That truck had a hard life and it will rest for now, I start her once every 2 weeks to keep things good and my buddy is going to buy it next month.
Sent from my Nexus 7 using Tapatalk 2
JamesinAbilene
