Bought HD grille and bumper cap
josueh95
josueh95
yea sure man no problem..i had to find them the hard way jaja but if you take of the grille assembly there are four bolts right under the bumper cap two more lower the the others..there is also two others under the corner lights these are alittle more tricky and the last two are on the far edges of the bumper right infront of the tires..the part where you have to cut once you remove the bumper it will become ovious..also not to sure on this but i believe these will need to be removed also because i dont think there is a way to lower these..they come of with that bolt you see there..it will eliminate four bolts but the main 4 will still be used to put the bumper back on..hope this helps a bit..also post pics of your progress man..id like to see how other rides also come along with the hd clip
TymanZ71
was wondering where u got your foglight bulbs from? love the look thou
scxgarrett
South Carolina
my foglights are 35w 6000k HID kit
hey man thanks for the info found them all lol got any pictures of the welds and how you did yours so i can pretty much do the same? also if you could text them to my cell 843-687-7283 because i will be doing it when i wake up in the next 8-9 hours so if you could get back to me as soon as possible thanks again man
josueh95
josueh95
sorry man i havent cut mine yet..but its not that hard just cut the frame and weld it lower but i wud add an L shaped metal and weld that on also to make it stronger
---------- Post added at 04:00 PM ---------- Previous post was at 04:00 PM ----------
finally sold my subs today for 550 soo i will be picking up my hd hood also this week :D
josueh95
josueh95
picked up my hd hood today..pretty pleased with the fitment no major gap issues
josueh95
josueh95
Now paint it! The whole front end, looks ten times better.
thanks man i love the change of the HD hood..this weekend if all goes well the hood will get painted along with the grille..the bumper will have to wait a couple weeks but also will be color matched..once hood and grille are painted i will cut the brackets and lower the bumper to install everything
LOWHOE775
Sparks,Nevada
Hey so what exactly needs to be done so I can put the HD front end on mine if u can please explain. Or point me in the right direction.ImageUploadedByTapatalk1362703884.605823.jpg
josueh95
josueh95
to do the HD conversion you will need 4 pieces..an HD hood, grille, and the upper bumper cap and the chevy bowtie for the grille..now for the grille to fit right you will need to cut the bumper mounts and lower then i believe an inch and a half and weld the mounts back on..replace the bumper cap and put the bumper back on, now the bumper will sit at the right height, after that simply directly replace the grille and bolt on the hood..hardest part id say would be removing the stock bumper cap and relocating the bumper mounts
chauncey0337
MLT, WA
Looks good. Can't wait to see it finished. I'm slowly on my way to doing this mod also, I'm just a little hesitant about dropping the bumper.
BLKHOE05
Arkansas
Do you have part numbers? I am looking at doing this but haven't found any specific part numbers for everything. And it seems that somewhere I seen that you need to use the hd bumper braces.
thanks
josueh95
josueh95
thanks man yea im with you on that about the bumper but once you take a closer look at ghe bumper mounts you can see thats its actually pretty easy its jst a cut, lower and weld back on. i personally love the hd look and i had to go for it
josueh95
josueh95
thanks
i dont have any part numbers sorry man but autoparts warehouse ebay amazon OEM and certifit carry all the parts. ive heard of that too but you would still have to cut and weld because the bumper mounts are part of the chasis
---------- Post added at 08:27 AM ---------- Previous post was at 08:10 AM ----------
Thanks for the help Very much appreciated that's my next mod
no problem..hd conversion gives such a mean looms to the tahoes..when you get to doing your conversion update me on the progress id like to see how it end up..good luck man
josueh95
josueh95
okay so i realized today a shop wants to charge extra because my bumper pad is textured soo its alot more work soo for now it will stay black and the grille will be painted along with the hood with the two tone..for 350 not a bad price and the work the guy does is real nice i wish i took a pic of a denali he had with raised flames really looked cool
CKendrick
