new bump stops
the big blue bus
richmond, va
where is a good place to get some new bump stops for the front and rear of a 95 tahoe? i have one thats still there and its barely hanging on. all the rest have dry rotted away
x95tahoex
ma
I'm in need of some bump stops too. Did you end up finding them?
steamroller
The South
Nope mines lifted so there's at least a 10" gap between the axle and frame. I don't tow or take it off any sweet jumps so if I bottom the rear out I've got problems a bump stop won't fix lol.
You could use those in the rear if you wanted, theres only 1 bolt holding them to the bracket in if I remember right
the big blue bus
the big blue bus
richmond, va
im goign to look at the one i have left today. mines not lifted so i feel i might need em. im doin bl but thats not changing the suspension so ill feel more comfortable with stops
the big blue bus
the big blue bus
richmond, va
im going to try and order those here this weeknd. i now have no bump stops on the hoe. they look pretty simple to change just the one bolt holing them in
GangstaCowboy
I know this is an old post but I believe I am looking for some of these. It is a square looking rubber block that sits between the upper control arm and the frame I think. The stock ones look totally different than the ones pictured above. Mine are held on with some kind of slide and are square shaped, not conical. Is that normal for the stock bump stop? Are they called something else? Rock auto does not seem to have them. My passenger side is missing and the driver side is rotting away.
PJS3
Funny... I have the same symptoms and question. Did you get an answer for this?
2003 Yukon SLT
_Dylan_
STAY FROSTY
that one is a universal one from the auto parts store.
You can get the right ones from lmc truck, just look in their catalog
Big Jim
