Freedom Motorsports
Absolutely nothing. We had a pretty good snow storm a couple of weeks ago. Right before it we detailed it REAL good and then BAM, two solid weeks of snow, salt, etc...lol
vjr021
Clearwater, FL
Installed my Corsa Exhaust and my Spohn Panhard bar...
Funny - they don't work well together. The clearance on the Corsa with the panhard bar is tight, and my exhaust hangar after all of these years has sagged a little.
had to order a new rubber hangar should be ok after that.
It just barely touches.
BUT
The Corsa sounds AWESOME. At idle, and low speeds very timid, once you open her up!!! Wow!!
Worth the $$$.
Rivieraracing
BUT
Worth the $$$.
Did you go with the sport or touring?
Yuko04
"SquareBODluvr"
MN
STILL wire wheeling in between everthing else...... I need to buy stock in wire wheels!
jdpber
GOLD MEMBER
The America
Mine needs a bath for the 2nd time this week. Guess that's on the agenda for this evening
VOLZ1207
Replaced the front windshield wiper pump in my 02 (it was cracked and leaking) $18 new. Gonna replace differential fluids this weekend
boozer
Wichita, ks
Washed it, scratch x it, polished it with maguires #7, polished the wheels, installed different rear sway bar end links and got an alignment. I've had this tahoe for 6 years and now with the wheels and the lowering I am now obsessed with keeping it looking the best I can all over again!!
VOLZ1207
Worked on my 2002 tahoe with 75 k miles this weekend. I did the transmission flush/filter with dexron vi. Changed transfer case fluid auto trac ii. Changed both front and rear differentials fluids. Blend door swapout.
Red_Raider
Derby, Kansas
Cleaned throttle body and MAF. Also ran some seafoam through the gas tank. Since I was under the hood I took the plastic cover off the the top of the motor and plasti dipped it white. Will share some pics later after it dries and installed.
wwiizz
