1995 yukon starting issues?
cburns002
New to me is my yukon,, sometimes will not start, turn the key and nothing.. Dash lights up and fuel pump can be heard..... Wait bout 15 mins and then will start with no problems.. Thought maybe security system but do not have factory remote.. Any kind of info would be helpful.
_Dylan_
STAY FROSTY
Do you have spark and fuel when it doesn't want to start?
C
cburns002
yes... only thing that lights up are the dash lights.. gettin an aftermarket alarm installed saturday
retorq
Kingman AZ
Good idea, trucks broke, get extra shit installed. Hahahaha
You probable have a bad wire at the battery, mine used to do that when I first got it. When I swapped the cabled out it stopped.
C
cburns002
Haha......
All the warning lights comes on.. Then nothing... Some say it bcuz of the factory security system but do not have the remote...
SunlitComet
OBS Jedi-Do Good
unknown at this time.
if you mean they all go out suddenly on there own or when you start it then clean your battery cable terminal ends as well as check your grounds.
C
cburns002
when i turn the key on tha dash lights up then when try to start it nothing... has only happen twice in two weeks since i owned it.. goin to check and replace battery cables
_Dylan_
STAY FROSTY
Ok you need to give us more details man your not helping us help you.
Is the starter cranking and the engine won't start? Or the starter doesn't crank at all? If it's not cranking can you hear the starter solenoid click when you turn the key?
SunlitComet
OBS Jedi-Do Good
yeah if the moment you turn the key everything dies if that is what you mean either something is goofy with connections, ignition switch or battery supply.
---------- Post added at 07:18 PM ---------- Previous post was at 07:17 PM ----------
just try cleaning them first dont spend money on stuff unless it is damaged somehow.
C
cburns002
WHEN i turn the key nothing.. all dash lights up, can hear fuel pump but no crank no attempt to crank.. NOTHING....its like its no battery connection but after bout 15 - 20 mins then its fine. and will start like there is nothing wrong..
_Dylan_
STAY FROSTY
Go over the battery connections and clean them and tighten them up. Or if the cable terminals are worn out, buy new ones.
Mohq
