What is the battery of choice?
pittmanb8
Unless you running a stereo for extended periods with the vehicle off, I would suggest the red top. You get more CCA than the yellow top and don't spend the extra money on the yellow top deep cycle which is unnecessary for most.
DarkTahoe00
IN
For powering Audio I use Kinetik one the best on the market there a Hybrid battery.
dropmech
Puddle Pirate
Coral Springs
I don't see any mods in your sig that would suggest you need to even spend money on an optima. For at least ten years now I've been running Interstate batteries in my vehicles. Even one with a modest stereo upgrade and I have never had a single problem with them. Just my two cents.
Modded
That Guy
Kinetik is a real good idea, they hold charges real long, and they aren't too expensive.
If you dont have a aftermarket stereo, or use just leave your car accessories on alot w/o the engine on I say you get one Kinetik Hc1800.
rigo_jones
going against
DENVER mexico
uhmm duracell... yellow top for me even tho im mostly stock (no system) it dont matter i feel more "safe" with an optima than a stock battery.
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
bosch, interstate megatron plus, or duralast are what have given me good results over the last couple of decades, i generally average 7 years out of any of them.
most modern 'wet' batteries are made by johnson controls (interstate, diehard, all parts store batteries, walmart, and yes, they make optima too)
I hope i can fit an mtl 85 (i fit one in my Eagle talon!) but I will probably have to stick with the mtp-78 (800 CCA and 110 minute reserve)
those that i have seen fail early (under 5 years) are
optima yellow
optima yellow
optima yellow
optima red
hunter/dynabatt/stinger (all the same battery)
nearly every 'dry-cell' light weight/compact battery (kinetic).
Whether it is because people are using deep cycles incorrectly, or abusing the batteries because they are 'stronger', or just because they are smaller and lighter as a result of less lead and thus are engineered for a shorter lifespan... i dunno. Probably a little of all of it.
as long as I've got 850+ CCA and a wet battery, I'm good. The bigger the better though.
NathanJax
Vacation Nathan
Jax, Fl
I use a Napa Orbital battery. Basically the same thing as a Optima Red top...
DenaliAK
Colder than you
Alaska
Damn...didn't know batteries were so complicated. I use a 850 cca battery that came with the truck. Seems to work just fine and I don't see much point in getting another just to say I did.
Durobans
