HID preference?
Crowder99Yukon
Looking to do an hid conversion. Which brands should I be looking for? I've been looking around just looking for suggestions thanks
Sent from my HTC One S using Tapatalk 2
---------- Post added at 12:14 AM ---------- Previous post was at 12:01 AM ----------
Furthermore is it worth it in an obs? With stock housing?
_Dylan_
STAY FROSTY
I've used ebay ones and they have worked fine for me. I have 35w lows and 55w highs both 6000k.
I wish I would have went with 4500k.
I would buy new housings and do the 4 high mod first. The factory housings suck. It's definitely worth it, vast improvement over factory.
---------- Post added at 12:35 AM ---------- Previous post was at 12:24 AM ----------
factory highbeam bulbs in clear housings taken a few months ago
different location(newer road with more reflection) taken a few weeks ago. 55 watt 6000k highs and 4-high mod with 35 watt 6000k lows. big difference
same location as above picture, but just the low beams
same location as first picture, low beams only
all pictures taken with clear housings
Blazed
Accepting Donations
Get new housings with clear lenses and hit up theretrofitsource.com
I've had three different HID kits you get what you pay for.
I've never had a kit bust on me just trying different kits and theretrofitsource has way better output.
Crowder99Yukon
Crowder99Yukon
What is the 4high mod? Is there a writeup on how to do it?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
your housings are out of alignment it looks like.
---------- Post added at 09:22 AM ---------- Previous post was at 09:21 AM ----------
running low and high beams at the same time when high beams are selected. in that mode the lows are shutdown as designed by the vehicle manufacturer.
Crowder99Yukon
Crowder99Yukon
Can't seem to find a writeup. Where can I find this?
LOWHOE775
Sparks,Nevada
I use the vvme ones go to their site or get em on eBay just make sure u get the AC kit their built better and don't flicker I have 55W AC 10,000k top and bottom no problems at all
95escahoe
I got mine from DDM, run 6k HID' s in the lows and silverstars in the highs, the Denali lights I run the lows have a glare cap on them which is a nice feature, had them for over 2 years and no issues and picked up an HD headlight harness with 4hi from Mean Green (highly recommend all plug and play no splicing)
Sent from my HTC One X using Tapatalk 2
carman2197
