ABS & Traction Control activated for no reason.
Leatherneck1775
Glad to be here and look forward to learning as much as possible about my vehicle. Thanks everyone.
2004 Yukon Denali came home with wife yesterday. Scraping noise from the front drivers side hub. Turns out that the hub nut need to be tightened. Not sure why but ok. The scraping continued to the end of the driveway and has not returned. After taking care of that, the ABS warning light and the Traction Control warning came on at the same time. When driving, the traction control comes on and will not allow more than 10-15 MPH. When braking, the antilock kicks in with pulsating braking. So braking is a problem, as is driving. Traction control button will allow greater speeds than 15-20mph, but not much. The only thing that changed was the tightening of the hub nut. so I am curious to know if possibly the hub ABS & Traction Control sensors were damaged with the loose hub assembly. I never did find the scraping part and think it might be internal to the hub.
Has anyone experienced any of this?
big_b_in_PA
Billy Badass
Central Pa.
Sounds like the wheel bearings are bad and throwing the abs sensor out of whack. Check for any play in the bearings. Does it make any kind of noise from that wheel? If so replace the hub assembly and all should be good.
---------- Post added at 08:58 AM ---------- Previous post was at 08:56 AM ----------
Edit: I know it made noise to the end of your driveway, but if you listen while driving, does it make noise when turning to the left or right?
ludvball
If the hub nut was loose, then it is possible the rotor was rubbing against the brake shield. As far as the ABS and Traction Control light coming on, I am having the same problem. Mine started out as just the lights coming on and loosing power. If i selected the stability button disable, then I would regain power. After about a week or two of this, i started getting the brake pulse when below 15 miles per hour. Occasionally I get a pull to the left at low speed.
The drivers side hub assembly had been replaced about a year ago. I just replaced the passenger side hub (it was in pretty bad shape), and it came with a new sensor. I also replaced the driver side sensor at the same time. The lights never went away, but the pulse and loss of power didn't happen again for about a week. Now all of the symptoms are happening again.
I just pulled the ABS fuse, and plan to clean the ground under the drivers door. I will replace the fuse and see if that resolves my problem. If not, I am going to have the EBCM module repaired. That seems to be the next step. Beyond that, I am at a loss.
Also, I have a 2" spindle drop and 3" drop in the rear, with air ride removed. I rear in one of the many threads i have seen that many with the drops get the lights, and just ignore them.
bjbrath
Wisconsin
traction control and anti-lock brakes come on
My 05 Yukon is doing something similar, the traction control comes on when accelerating from every stop, I can press the traction control button to turn it off and then I can drive it more than 10mph. But even with the traction control disabled, the anti locks come on every time I stop the truck. I've replaced both front wheel speed sensors and checked the resistance of the speed sensor in the transfer case comparing it with a new one, and they were the same resistance. I've talked with a couple of my mechanic friends and they told me to make sure the surfaces that the front wheel speed sensors mount to are very clean, they said even a little bit of rust can throw them off. I've cleaned them but the problem persists. I'm going to check the wheel bearings, but I can't hear anything that would make them seem like they need to be replaced. Please let me know if anyone has found a fix for issues like this, and when I figure it out, I'll do the same. Thx, BJB
geddy2112
I had this problem that made me go bonkers for months. Lucky my Yukon was not my DD. I replaced and did everything i could to the ABS sensor to try and eliminate the problem. Finally, i decided to replace the whole hub assemble. Bought the Timken hub assemble from Rockauto, replaced it. The problem solved. No matter how much you clean the sensor or the hub of rust, it will not cure the problem. Replace the hub and save yourself the headache. I had no signs of bearing wear either.
Hacker-Pschorr
My 2003 Denali is doing something very similar.
Taking off from a stop the traction message will come on and my truck will not accelerate. If I wait a second or two everything will be back to normal. If I turn off the system, no issues at all.
This only happens maybe once per week (if that often) when driving the Yukon every day.
This is so infrequent it’s hard to diagnose. Would only the front sensor be in play here? I’m assuming there are also speed sensors at the back.
tx01tahoe
TX
My traction control light doesn't turn on but my parking brake and ABS light turn on randomly. I already had it tested and it is my brake module. I've been meaning to pop it off and send it in to module master to have them rebuild it. I am not sure if that is the problem you all are having on the Denalis but figured of share.
cowboyzr2
Magnolia, TX
I had a very similar problem with my ZR2. All the same symptoms without traction control (not an option).
I've replaced my front hubs a couple of times... The last time I changed one, my ABS starting acting up - coming on randomly. What I didn't think about was I used the OLD ABS sensor and not the one that came with the hub.
I drove it for a year with the ABS fuse removed until I replaced the hub assembly again. This time, I used the ABS sensor that came with the new hub. Problem solved.
Turns out a few people on the ZR2 forum had the same problem - and it looks like at times ABS sensors are sensitive to the hubs they are paired with... No idea why. So far it's happened to me twice.
yukon05
I had the EXACT same problem with my 05 yukon xl, and only when accelerating from a complete stop. Replaced both front hubs, and all has been well since.
Hokie.1996
2004 Tahoe
My '04 Tahoe makes a humming sound from the front wheel area, but only at low speed excessive turns, like turning sharp out of a parking spot. it is the same sound that happens when the traction control and ABS kickin on ice. Could my bearing be warn enough to throw the sensor out of proper alignment, and the excessive turn radius amplify the effect? i was considering buying the TIMKEN hub assy with new sensor from rock auto? Please Help
yukon05
id go with timken i wish i did but money was tight
and we were leaving for florida in two days so i bought the
cheaper ones. i just threw a code for my right front wheel speed
sensor abs light and tc light came on. luckily my parts place
warrantied it but lesson learned for next time
turbogmc
Viroqua, WI
Mine did this same crap when i got it, i just keep pressing the traction buton because the bearings are still nice and tight. Hard to spend the money just to make a light go away.
Al Seuell Jr
2001 Yukon XL similar issue, when starting the truck the low traction & traction off lights flash once then turn off, indicating the system is on, when put in drive will not go past 10-15 mph. I press the button and it drives normal. This issue began when I replaced my throttle body sensor (gas pedal) which also prevented me from accelerating past 10-15mph... How can I get the traction control to stay off?
alwyswntd1
I'm a noob,3 days ago same issue both emergency brake and abs both kicked on,i owned a blazer at one time as well,the issue with the blazer where the ground straps under the driver side found rust build up,went ahead cleaned put back all was good.remembered that issue did it to my new to me 06 Tahoe when they came on i cleaned the said rust same area and all is good now,not sure if it will help anyone but its worth a shot....
X-ray Nerd
