Filling the Wheel wells
jjphigam
so i'm wondering if anyone out there knew if i could fit a set of 34 or 35 inch tires on a 04 Yukon SLT with just a leveling kit or if that would require a suspension lift. i'm really going for the full wheel well look.
roush611
You are going to need more than a leveling kit. 33s barely fit with a leveling kit.
04white-z71
Yeah 33's will fit with a leveling kit. Any bigger you are going to have to lift.
imi4tth3w
how can anyone make a suggestion to a question so vague?
for one, anything is possible. you can bet your sweet ass there is no way in hell you will fit my 33's on your truck with just a leveling kit. thats because i have 20x12's and 33 12.50 20's.
are you planning on running stock wheels? aftermarket? what size? what size tires do you have in mind?
if you want the stuffed look, you need a positive offset wheel with a tall, narrow tire. otherwise you will be doing lots of cutting and rubbing. if thats your thing, all to ya. but it's going to cause problems in the long run.
Brad.r
I am tucking 33in All-Terrains on factory ride height.
01yukon
Lynchburg, Va
I got a leveling kit and 2 inch spacers and running 34.4's with some trimming.
Mohq
