Dylan's 1997 GMC Yukon
_Dylan_
_Dylan_
STAY FROSTY
I really did not go over this thread, but I went over your GMFS thread. Dude, re-do that wiring. You could seriously burn down your truck. It's hack-tastic. I did not notice, but did you even upgrade the charging system in your truck to handle that?
Seriously, fix that wiring asap. Your box looks awesome, great job on that. And I'd ditch the mirror thingy. It looks cool...on a JDM car. Not a American suv. Plus, that JDM mirror does not look right when you put a 1940's GMC emblem on your truck. I like the emblem. I'd color match the bottom section of it and I think it would look sweet!
Not trying to be a GMFS *******, just trying to give some advice
If you're talking about the mess under the back seats, its getting redone in a couple days when I wire my speakers to the 2 channel amp. No I haven't upgraded the charging system, its only pulling 80 amps max. I'm not experiencing light dimming or anything. I do have a slightly bigger battery and I've been meaning to do the big 3 upgrade soon.
_Dylan_
_Dylan_
STAY FROSTY
driver side done.
crappy iphone video
http://www.youtube.com/watch?v=pBj6pRbhzX0
Sounds really good for the money I spent (around $150) and its way better than before.
Wiring is cleaned up, I try to get a pic of that tomorrow.
foreverfalcon40
Get a diehard platnium battery. Side and top terminals...LOVE the emblem. ditch the mirror.
_Dylan_
_Dylan_
STAY FROSTY
Thanks man, I have a side and top post from advance. I don't remember the brand, I think it was an autocraft 800 cca. The big 3 is next.
_Dylan_
_Dylan_
STAY FROSTY
Sounds good! :thumbup:
Thanks. I'm very satisfied with the speakers. This is my first speaker set that is running off an amp. 200x2 watts puts the factory 10x4 watts to shame. :cheers: I paid $50 shipped for the soundstream components and $65 for the pair of PPIs. Next phase will probably be a bigger box with some real subwoofers. :D
I didn't have to cut the door structure to make the 8" mids to fit, it was very easy if you have the tools to cut the hole. I used a $20 jigsaw from harbor freight. Fishing wire was easier than than I expected...
_Dylan_
_Dylan_
STAY FROSTY
intake gaskets replaced a few months ago
cavalcade emblem
---------- Post added at 09:05 PM ---------- Previous post was at 09:02 PM ----------
new tires, low mile goodyears off a jeep wrangler. 255/70r18
4 high done
---------- Post added at 09:08 PM ---------- Previous post was at 09:05 PM ----------
lows
highs
new tires installed
new rotors and pads
new distributor cap
dash cam
picture of the mount (has since been moved to the bottom of the window)
_Dylan_
_Dylan_
STAY FROSTY
just took it on a 2000 mile road trip, ran perfect
divider added to my subwoofer box
---------- Post added at 09:18 PM ---------- Previous post was at 09:12 PM ----------
replaced my broken CHMBL
bose 4" speakers installed from an escalade to replace the boss 4x10, but they turned out to be broken. I'll buy some better 4" speakers some day...
went to the junkyard and found a cupholder, fog light switch, reel light, and 12V socket. Score!
reel light installed, it has about 12 feet of cord
---------- Post added at 09:21 PM ---------- Previous post was at 09:18 PM ----------
florida edition emblem from a crown vic :D
intake resonator capped
I'm adding GMT800 windshield washer nozzles. They mount to the wiper arms.
_Dylan_
_Dylan_
STAY FROSTY
---------- Post added at 09:28 PM ---------- Previous post was at 09:23 PM ----------
adding a 2nd pump to the washer tank
loosen clips
10mm bolt
13mm bolt
7mm bolt
10mm bolt, then yank really ******* the tank to pull it out
hole drilled in the spot where the rear pump would go if I had a rear wiper. Gotta be careful where you drill or the nipple won't fit when you try to shove the tank back in the truck.
nipple and gel glue
hose installed
I have a 90s nissan pathfinder washer pump I'm going to add tomorrow
---------- Post added at 09:31 PM ---------- Previous post was at 09:28 PM ----------
I picked up a new camera finally, so I can get some good pictures. :)
The zipties on the washer nozzles is temporary, I might have to change their locations to adjust the spray pattern.
_Dylan_
_Dylan_
STAY FROSTY
made a half assed patch job on my seat
found a 120mph cluster and installed it
but the fuel gauge wasn't working correctly, so I put the stocker back in. I replaced one on the broken LED lights while it was out and moved the digital voltmeter to the inside of the cluster.
also picked these up yesterday
Merch619
