NNBS Kelderman air suspension kit
Status
Not open for further replies.
Goodinblack
I Like Tacos
Dirty South
I was really considering just doing the REAR in airbags and the front on drop struts.
so 2 bags in the back and the brackets, one tank and compressor
NathanJax
Vacation Nathan
Jax, Fl
for that, your gonna need the entire kit, minus the front bags and hosing. yo could get rid of 1 tank if you wanted to, but do THIS setup in just the rear is only gonna save you $500 or so...
yates ™
Resident Apple hater
Iowa
In order to do the rear system only you could eliminate a tank and still use the brackets to hold the one tank in place. The problem is the controls (Touch pad system, valves, sensors) are only set up for a 4 corner system and will not work for a 2 corner system. The other thing to think about when only doing the rear is that ride height is around 2" lower then stock so if you lower the front say 2" you will still sit 2" higher in the rear.
I am not going to offer different solutions in this thread because it is Chads for sale thread.
Blazed
Accepting Donations
So at comfortable ride height this kit is 2" lower than stock on all four corners?
sick1166
can this unit be used on a non air tahoe ,I looked at their website and it seem to say for autoride only? sorry I dont know much about this system but very interested in adding it to the hoe 2007 tahoe non auto ride is your kit all i need or something else? thanks, andy
yates ™
Iowa
Yes.
It will work for either and Chad has what you need!
iwaslowr
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
If you do not have OEM autoride height sensors you'll need the one's that I'm including in this sale. :Handshake:
Yes.
Sensor kit has already been purchased, and is included. :Handshake:
Shit sorry I get the 2 threads confused. I will edit my post and you edit the quote. :Handshake:
No problem Yates. :Handshake:
Blazed
Accepting Donations
So at comfortable ride height it's still super raked?
yates ™
Iowa
You could set the back down to even out but I would recommend getting brackets norcal sells for the shocks. I think I had my front and back set a little lower then the 2".
iwaslowr
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
I just so happen to have the DJM rear shock/sway bar relocator kit as well... If the buyer wants those parts in addition to the Kelderman air suspension I'm sure we can work out a deal.
iwaslowr
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
To help me re-coop as much as possible from my investment I have to keep the tanks as a pair and same goes for the pair of compressors. Shoot me a PM with offer if you'd like the rear bags with associated brackets.
NathanJax
Vacation Nathan
Jax, Fl
bidding on all 3!!!
Goodinblack
I Like Tacos
Dirty South
So to those that know........
It seems this kit would only control all four corners...... Since I would like to do only the back what options is there to control it?
When the back is at ride height, which is 2 inches lower than stock........ what should the PSI be in the bags?
Also, If I did manual fill, how much air do the bags lose every day, just sitting?
yates ™
Iowa
In order to run the back bags with any type of controls like how this works you would still need a tank and a place to put the compressor/s and one of the different options to run just a 2 corner system.
I honestly have no idea how much PSI is in there it would be something you would have to play with to find out but you could T the bags together which I would recommend or you could fill each bag manually.
They shouldn't lose any but the possibility is always there.
GalaxyBlackEsky
BlackedoutLT3
MD
HOLY Shit did that full kit only sell for 1400?? If so I would have bought it for that much!!!
Status
AdrienR
