Tow/Haul "performance" mode?
Lockout888
I'm confused about the Tow/Haul button and the BB "performance/track" option. Can someone explain what changes are made?
Can you still tow a heavy load with the "performance/track" engaged, or should you use the standard mode?
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
I have it. It turns your tow button into a Sport mode. Mine is set up to remove all Torque Management. The shifts are more firm and really make the truck peppy. With this mode on, i tell everyone that i can chirp my 22' tires in 1-2 shift and 2-3 if ground is wet, You will have to talk to Justin to figure how you want the sport button set up.
Goodinblack
I Like Tacos
Dirty South
So if the button is NOT in tow/haul then the truck returns to all factory settings?
If not can this be done.
Also, if all Torque Management is rid of, will it fry the transmissions?
JennaBear
Resident Ninja
San Diego, CA
Sorry, I don't understand what you are asking. You can either keep tow/haul in stock form and optimized for towing. Or you can have it in a sport mode.
If you have a mechanically sound transmission and aren't a harsh driver, there should be no issues, but we typically recommend 75-80% removal. Most folks who do the scan cable or AutoCal tune, just have Justin change the TM based on what he sees in the logs.
willcla
B'Ham
Is it possible to have 1) stock mode 2) Tow mode and 3) BB Tune (Sport Mode)?
Or is it only possible to have 2 modes: 1) stock and 2) BB Tune, activated by pressing tow/haul button?
Blazed
Accepting Donations
I believe you can have only two modes per tune file and they could be whatever you want.
For instance :
Normal - tow haul button
Bb tune - sport mode
Stock - sport mode
Bbtune - tow haul
Etc
Sent from my iPad using Tapatalk HD
willcla
B'Ham
For instance :
Stock - sport mode
Bbtune - tow haul
Etc
Thanks Blazed, I have another scenario for you
Lets say I have a BB Tune and also Tow Mode, could the tune get wiped if I have to take the Yuk to the dealer and they run a diagnostic on the PCM?
JennaBear
Resident Ninja
San Diego, CA
BB tune is never activated by the tow/haul button. The tow/haul button controls transmission settings only or, activates the BB Sport mode if so equipped.
Blazed
Accepting Donations
Ok see I wasn't sure thanks for clearing that up!
I respond first to lots of threads :win:
Blazed
Accepting Donations
I think they mean to 911
And what is your military discount?
TejasPitt
