Fuel gauge going crazy
rosendo192000
Today as I was on my way to a town over , I noticed my fuel gauge was acting weird . Durning my drive I looked at my gauge and noticed I had 3/4 of fuel when I knew I only had 3/8 . I got to my destination turned the truck off and turned it back on , all the sudden it went to a 1/4 which seemed actuate . So on my way back home I paid close attention to my gauge and fuel level goes from accurate to zero for a minute and back, but the "low fuel light" never came on (because there was actually plenty of fuel) . No hard starting , rough idel , poor acceleration nor CEL . Do you guys think I should change my pump soon or is it a sensor (is there a sending unit ) that might be fault . If it is the fuel pump should I change anything else while I'm at it ?
edgaranah1
Corona California
My guess would be the fuel pump. I had the exact same thing happen to a 01 silverado.
Sent from my iPhone 4g using Tapatalk
HOE-N-IT
Virginia
My guess would be it is the sending unit located in the tank. I don't know why a fuel pump would affect the gauge but I'm no expert.
GM recommends the use of their Fuel System Treatment Plus if you do not use top tier gas. The "Plus" is an additive that counters the effect of sulfur in the fuel that over time can cause problems with fuel sending units including eratic readings. Do a search on "GM Fuel System Treatment Plus" and you will get loads of information. I use the Techron Plus fuel system cleaner which is the exact same thing only a lot cheaper. Again get the Techron PLUS and not the regular Techron.
rosendo192000
rosendo192000
Thanks guys , I just thought there was an external sensor that might control the gauge that had gone bad. Ima top of my tank and dump some additive (which I have done in the past ) and hopefully it stabilizes. If not I guess I have no other choice then dropping the tank and switching it out the pump since I believe that the pump and sending unit is one single unit .
2007tahoe
The sending unit and pump are one assy. You can change them separately but if you go threw all the trouble to drop the tank, might as well change the hole assy. My gauge goes crazy also. Gm fuel pumps suck at life so I will just wait for it to go out before I drop the tank for the sending unit. A cheaper assy is about 400.
rosendo192000
rosendo192000
Thanks , yea I did see it listed on GMPARTSDirect for 366 .
Gzes
the drifting 2dr
Wichita tx
Yep its the fue pump assembly. I waited too my pump blew then swapped everyting
edgaranah1
Corona California
I wonder why there so damn expensive. They use cheap plastic pretty sure they spend like 20 bucks making them.
taktikz
same thing happened to be recently. strange, but i can't figure it out
mike1944
Glide, Oregon
Earlier Corvettes were very susceptible to this problem.
Experts over on the corvetteforum always recommended you burn a few tankfuls of Chevron with Techron before you start changing stuff out.
Often as not it would it free it up.
D Rollins
