$$ advise on a 5.3L donor truck
99TanHoe
Louisiana
In know its not a Hoe that will receive the swap but I'll ask the question anyway. I may have found a donor truck for a 5.3L swap on my old 95'GMC.
I haven't had a chance to go look at it yet but the body has already been parted out.
Body wise, all thats left is the cab shell, the front frame, front axle and the rear frame and gas tank.
Mechanical and other parts I would get along with the above mentioned body shell:
Motor, trans, wiring harness, air conditioner compressor, computer, gas tank and gauge cluster.
Its a 2000' model 2wd truck and he says it had 160,000 miles on it when it was wrecked. I would be putting it in my 95' 2wd 3/4 ton to replace the 350tbi. He's asking $1400, I was thinking about offering $1000 to see how bad he wants to get rid of it.
What do you think, Great deal, Good deal, Run the other way?
99TanHoe
99TanHoe
Louisiana
Run! We paid less than that on a 2005 6.0L and transmission for a swap into our 72 K5.
How much did you pay, if you don't mind me asking? I'd like to know what price range to be looking for.
I'd definitely talk him down considerably and see if you can't hear it run first. 160k either doesn't mean a thing if it's been maintained properly or 160k could be a worn out dog if it's was mistreated and not maintained.
Donnie Yukonie
Yates Caretaker
honestly why swap? your not looking at that much more power or mileage gain either way i would either swap as mentioned above a 6.0 or a BEASTY 8.1 =)
hard to find parts for an 8.1. A 5.3 will be perform considerably better than the TBI 350 that's in his 95 now. He'll notice a pretty big increase in power, performance and MPG.
Donnie Yukonie
Yates Caretaker
sorry i missed that part 95 Tbi yea Nvm thats a noticeable increase i was thinking of the vortecs
jdpber
GOLD MEMBER
The America
thats worth about $450 in my book for those miles.
992dr
Eastern N.C.
I would talk him down to at least half of what he is asking. You can get 5.3s all day long on the bay for 6/700 shipped to your door. Unless you can grab a 6.0 for that amount or less, go for it. Otheriwse, I'd stick with any LS based before going with an 8.1, like said, parts are not plentiful.
redaddiction
I'd take everything he had left for $800 if I was you, all the little pieces will help you quite a bit if you decide to swap. Sell the extra parts and you'll be able to recover some money.You can get 6.0's for around 800 but they will be from Junkyards and you'll still need a new transmission.
---------- Post added at 08:07 PM ---------- Previous post was at 08:06 PM ----------
For the record I picked up a 5.3/4l60e for $350.00 sounds like a good price to most until you factor in all the little parts you will need. Luckily I have tons of ls1 parts from swaps I did in the past.
JennaBear
Resident Ninja
San Diego, CA
We got our engine, transmission, and other parts for $1700. Got my cousin a 6l for 1200 as well.
Sent from an ice cream sammich.
99TanHoe
99TanHoe
Louisiana
Thanks for all the replies,
I see there's alot'a love for 6.0's here. I think I can get enough power out of the 5.3 for what I want to do with it. I drove the truck for 13 years with the anemic TBI motor, that little 5.3's going to feel like a racehorse to me.
Besides that it should get decent mpg. We had an 03 Yukon that would get 20mpg on the hwy.
My truck has a 5 speed manual transmission that I refuse to part with. I think all I will need is a bell housing from a V6 to mate the 5.3 up to the manual trans. That way I can maybe sell the auto trans and get a little back.
There's no way I was going to give him the full $1400. Depending on the condition I'll try low balling him and see what happens.
You'll be happy with a 5.3. Good, reliable motor :waytogo:
redaddiction
Keep in mind once you do the swap and get it running you can always upgrade the longblock in the future. That is my plan get everything situated and then down the road upgrades will be easy.
992dr
Eastern N.C.
I think you will be pleasantly surprised with the 5.3 especially mated to a 5 speed.
Like 07 said, good reliable motor that has some very surprising potential.
99TanHoe
99TanHoe
Louisiana
Gotta revive this thread for a question.
The guy thats going to do my wiring and tuning for the swap isn't sure about the mechanical matchup between the 5.3 and the NV4500. At first he thought that all that was needed was a V6 bell housing but now he's not sure.
I did alot of searching and can't turn up anything that gives me the warm and fuzzies about the mechanical end of the swap. I even started a thread over on the Performance Trucks forum and didn't get much of a response.
If someone could point me to some good information on combining the 5.3 with the NV4500 I would really appreciate it. I need to get past the preplanning/is-it-even-practical stage.
The truck is a 2WD so there won't be any transfer case issues to deal with.
Trippers99hoe
SW Oklahoma
Hope this helps...lots of good info on LS1truck forum.
Bolting up a manual tranny:
This was the first thing I needed to make sure of. It seemed all the forums had vague information and most people were not getting the answers they wanted about the swap. "Do it like this and it will work they said". I needed to be sure. I didn't want to have to pull the heavy NV4500 back out because I didn't do my homework. After nearly 6 hours of browsing forums I learned that the 99-2000 LS engines had a shorter crank than the SBC engines. Later on they became longer but were still a pinch short. Advance adapters sold a kit for nearly a grand but that was outrageous. The large price was because of a smaller bellhousing that would make up the difference in the crank length. An SBC clutch will bolt to the LS Flywheel as long as the dowel pins are removed. The only issue with using an LS flywheel is that the bolt holes are metric and the holes will need to be reamed out on the pressure plate. There was also an aftermarket flywheel for the cheap that was more designed for mating old trannys to the new engines as it was standard thread for the pressure plate bolts but metric holes for the connection at the crank. I went this route. Also the pilot bushing is different, use one from an LS2. Of course I had to wait until the flywheel and pilot bushing arrived and then take measurements to confirm. I probably dug into this too deep as I actually measured and confirmed the face of the new flywheel .2” closer to the engine and the pilot bearing .13” closer to the tranny. Since the input shaft end is very long, the pilot bushing was of no concern. At the time of the installation, all I could hope was that the .2” of clutch engagement would be made up by the hydraulic system. Once I was able to drive the truck, my presumptions were right and everything was fine. I was able to use my old NV4500 bell housing, clutch, pressure plate and slave cylinder. The only new purchase was the flywheel, flywheel bolts (don’t reuse old) and pilot bushing. It should also note that since the LSX engines are all metric, the bellhousing bolts I had were no longer going to work. Also when putting the engine on the engine stand, I had to dig up metric bolts to make the connection. Since the LSX engines don’t use one of the upper bellhousing bolts, I chose to move the upper arm on the stand to the lower bolt hole position, thereby keeping 4 bolts connected. Since I have the first gen NV4500, I have the external slave cylinder. This bolted right up, but was very very close to the plastic plug for the oil level in the oil pan. Most of us doing the conversion will not need to plug anything in here. If you plan on using it, make sure you don't have an external type slave cylinder.
the thread is on ls1truck forum here.
http://www.ls1truck.com/forums/lsx-...-gen-i-nv4500-conversion-detailed-part-s.html
99TanHoe
99TanHoe
Louisiana
Thanks a bunch Tripper,
That guy needs to put all that info into a book and sell it. Pretty much covers every aspect of the swap, besides that he explains how to do it on the cheap.
Trippers99hoe
SW Oklahoma
Your welcome,
He did a very detailed write up.Hope it helps get you where you want to go.
Drewphil
