New here need your feed back
westxburban
west tx
JUST TRADED MY TAHOE FOR A BLACK 2012 BURBAN LOOKIN AT BLACKING OUT FRONT GRILL AND MAYBE A 2/3 DROP ON SOME BLACK 24" BEEN READING ON HERE ABOUT PROBLEMS WITH stabilitrak GOT ME THINKING ABOUT DROP ANY AND ALL FEED BACK WILL BE APPRECIATED WILL BE PULLING A TRAILER WONDER HOW OR WHAT NEEDS TO BE DONE SO BACK END WONT DROP TOO MUCH WHEN PULLIN TRAILER ........ THANKS
CHOO CHOO
BackPagePhil
Manheim, Pa
Welcome aboard! First, turn caps lock off. You can do a 2/3 drop no big deal on the stabilitrak light. Mine comes on occassionally. Hit up tony or norcalss for your dropkit. Do helperbags for your towing. If your gonna run 24s and tow, i would do the 305 tire instead of a 295. Quality tire is key. Keep us updated as to what you do!
Sent from my DROID4 using Tapatalk 2
W
westxburban
west tx
Ok thanks for.the reply other than greasing and changing oil and tires im not mechanically inclined whats the difference in the rim offset what does it matter? And id like to get a black bowtie also seen it on amazon but says it doesn't fit my 2012
On the bowtie just have your stock one painted and be on your way. Should be a quick, easy and cheap job :Handshake:
As for the drop, the only time the Stabilitrak light has come on due to my drop (2/4) was when changing out rear shocks and accidentally unpluggin the sensor :chicken: I just plugged it back in and on my way and no light since then :party33:
Welcome to TYF!
Goodinblack
I Like Tacos
Dirty South
I second 07Burb..... Only time for me has been during the shock install. Yes, it freaked me out too......I hate the dealership.
Definitely need Airbags.
emay
S. Elgin, IL
The only time I have ever heard of the stabilitrak problems was with folks that tried to install without fully disconnecting the sensors and hyper extending the lines when lowering the axle to pull the springs. Avoid that and you will be golden.
TejasPitt
