Tire sizes !!!!!!!!!!!!!!
Donnie Yukonie
Yates Caretaker
ok so i gotta get new tires for these rims i got http://www.summitracing.com/checkout/cart.aspx i need the actual tire size for a 35 ??? i have no idea what pmetic/emetric/LTmetric or non of that Bs is help??
PS the sooner you guys help me with this the sooner i can get them mounted and show you pics :deal:
retorq
Kingman AZ
You can't post a link to your shopping cart ...
You mean like 35x12.5x17?? My GF has some for her Ramcharger.
_Dylan_
STAY FROSTY
metric tire sizes are in millimeters, 25.4 millimeters in an inch
A typical 35x12.50" tire will use a 10" wide wheel. Don't use a 12" wheel with a 12.5" tire it looks stupid.
KPOD
Michigan
I think 18x9 or 18x10 is as big as you want to go for a 12.5" wide tire right? I'm still debating myself if I want 9 or 10" wide rims.
That is a LOT of exclamation points in the subject....that is all
_Dylan_
STAY FROSTY
Either one is fine. When you put a 12" wheel (or wider) on a 12.5 tire it looks dumb and you risk popping the bead off road.
HDRock1
Flint,Mi
Tire--BFG KM2,35X12.50x15
Wheel--Unique Steel Seris 297(same as Crager soft 8's),15x8
True tire hight at 28psi is 33.25",brand new tire,zero miles. (on KJ @ 6000lbs)
Tire: BFG MT KM2's, 35x12.5x17
Wheel: 17x8 ProComp 7098's
At 33psi, actual height mounted with the weight of the Jeep is 33.75"
Tire: Cooper Discoverer STT Tek3, 35x12.50x17 (Advertised 34.7x12.7)
Wheel: Stock Moabs 17x7.5"
At 30psi, 34" even (about 4K miles on the tires and rotated once)
Tire: Goodyear Duratrac 315/75R-16
Wheel: 16x8 Procomp Xtreme Alloy 7089
Actual height: 34.2" (advertised 35")
Tire: Goodyear MT/R Kevlar 35x12.50-17
Wheel: Raceline RT-233 beadlock, 17x9.5 (actual measurment closer to 10")
Tire height, mounted at 26psi - 34.25"
Tire: Nitto Mud Grappler 35X12.50R17
Wheel: 17X7.5 Stock Rubicon Moab Rim
At 35PSI -- 34.25"
Tire: Pitbull Rocker 35x12.5-15 radials
Wheel: new Cragar V series 15x8.
Actual height at 30 psi is 34.5" measured at the center of tire with a level. Probably makes a difference if measured at edge of tread.
Tire: ProComp Xtreme M/T 315/75R-16
Wheel: 16x8 Procomp 7089
Actual height: 33.3" (posted height 34.6")
Tire: Toyo Open Country M/T 35x12.50x20
Wheel: 20x8 MotoMetal 0950
Actual height: 35" (posted height 35.2")
Tire--Toyo Open Country MT,35x13.50x15
Wheel--Ion Alloy 174,15x10
True tire height at 28psi is 34.25" at 17/32" tread depth,new tread depth is 21/32". (on KJ @ 6000lbs)
Wheel--Unique Steel Seris 297,15x8
True tire size at 28psi is 35.1",brand new tire,zero miles. (on KJ @ 6000lbs)
33's
Falken Rocky Mountain's 285/75 r16- 32.8" - need more info on this combo... will PM user
32's
Tire: BFG ATs 265/75/16 Load Range E
Wheel: Stock 16x7 Alloys
31.75" at 33psi
Tire: Cooper Discoverer STT 265/75 16
Wheel: Stock 16x7 steelies
True size: 31.5in high 10in wide
Tire: Hankook Dynapro LT295/75x16" MT Advertised 33.6"
Wheel: ProComp 16x8½"-8089 series
mounted 30psi--33.2"
kaoticlife
Port St Lucie, Florida
Police officer: excuse me sir what do you think you are doing?
HDrock1: Uh officer I am running around town measuring these tire and wheel combinations
for the guys on this website forum!
bowtiefreak
No Quarter
Near Philly
big tires are stupid. I ditched the 35s for these bad boys!
Drewphil
