Where is your radar detector mounted?
snowjay
In my last two vehicle I had it mounted on the windshield just above the rear view mirror. I would then either tap into the overhead wiring or run the wire across the headliner down behind the A pillar into the fuse box. But I can't do that on the Tahoe because of the "camouflage" printed on the window and the suction cups don't stick very well.
I could put it to the left of that on the plain glass but it then almost becomes too close to me and I'm not too crazy about the idea of having it below the mirror as it's too easy to see from outside. I thought about a visor mount as well but that puts it almost over my head and I just can't quickly glance at it.
Where is yours? Other ideas?
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
I personally don't own a radar detector, but how about just behind and/or below the rear view mirror? That is where I suction-cup my front plate to the windshield when needed...
Modded
That Guy
I ahve the 9500ix and its hardwired into one of the ignition wires behind the dash. I was aiming to mount it in the viso with a clip but like you said that puts it right ontop of my head (I still may do it and see, but you can always go first and post a pic :))
So as of no its right on top of my registration and inspection stickers on the bottom left driver side corner. Works good from there and reduces exterior visibility.
destroyer1362
A work in progress
Midlothian, TX
I have seen a Yukon that had an overhead console spot just for the radar detector, it sat right above the mirror. I've also seen them velcroed on top of the dash, it's not as apparent as it would be suction cupped to the windshield. Thats what I would go with.
snowjay
snowjay
Have you seen this for your ******?
http://www.countryjoycrafts.com/350Z/escortmount.htm
---------- Post added at 08:03 AM ---------- Previous post was at 07:55 AM ----------
I never liked on top of the dash, plus it reduces the effective range of the detector as well. Higher on the windshield is the preferred mounting location.
Modded
That Guy
Thats intersting man, I need to go measure my mirror stema nd see if it will fit.
snowjay
snowjay
Let me know. I'm using an old Whister I got in 2004, but I was about to pull the trigger on a V1 before I decided to get the Tahoe.
I'd love to see how it looks installed if you get it.
05Yukon
Houston
I have my valentine hardwired in my 05 that has the little dots and I dont have a problem with it holding with it resting on the mirror. I have also used it in my 08 Yukon and didnt have any problems with it holding. I always put just a little bit of spit on the suction cups when putting it up and never have problems with it falling down.
snowjay
snowjay
Mine wouldn't stay up for 2 minutes even if I wet it.
I had an idea though. Instead of using suction cups I could get a some of that "clear" hook/loop stuff like they use for toll tags to hold it up on the window. Then I'd never have to worry about it falling which it did a few times in my last car.
KMeloney
I have my V1 mounted to the left of my rear view mirror with an Invisicord connection to the back of the rear view mirror. It's not too close to me, and its line of site isn't blocked by anything.
If your suction cups no longer stick, then you just need new suction cups.
/< / /2 /<
Big Jim
