What light is this?
Smasal
Southwest, Mo
The inside Amber light never comes on? Are both bulbs out? Does it even work? I'm confused. Hopefully someone has an answer here?
Alex33
That's your Daytime Running Light. If both are out, you're bulbs are probably just burnt out.
03Dnasty
Kansas, Rock Chalk!!!
I believe you are talking about your Daytime Running Lights. If this is the case they only come on during the day, when your headlights are NOT on and the truck is out of park. When I bought my truck, both were burnt out and I had to replace them. Common thing to happen when they are supposed to be on 90% of the time. Anyways, bet if you swap those bulbs out, they'll work! :happy107:
soulsea
Bar
If it's not the bulbs check the fuse ... not sure if you bought your truck new or used, but some people don't want DRLs and they pull the fuse.
Smasal
Smasal
Southwest, Mo
The guy I bought it from could have pulled the fuse.He was big on appearance and may have just not wanted drl's. I'll swap bulbs tomorrow for starters. Thanks guys!
Smasal
Smasal
Southwest, Mo
Wow...that's what I meant. LEDs would be nice. These look kind of dull under hids.
Rivieraracing
E brake is off in pic. Thought of that myself before I posted haha.
So, your truck was on, in gear, with the emergency brake off with nobody in the drivers seat to hold the brake in?? :boxed:
Say it isn't so, please!!! ahhahahahaha
Smasal
Smasal
Southwest, Mo
In was in park with ebrake off. Drl's should have come on right? I've only had an NBS for a week. Cut me some slack. My OBS drl's came on when key was turned. Ebrake on or not.
JochenWoern
Sacramento, CA
DRL's will NOT come on if the truck is in PARK.
E-Brake off, Truck in Gear, this is when they come on.
You are correct, OBS worked different. But, I almost want to say that on my OBS the DRL's as well did not work WITH the EBrake on. :think:
Smasal
Smasal
Southwest, Mo
I'm in driving right now and I'm behind a truck at a red light and I can see that my drl's are not on. I'll check fuses later
alc5m
obs turned off with parking brake
Buford bubba
