Installing Overhead Dvd Player
finman
oklahoma
i am going to be installing an aftermarket overhead dvd player in my 2011 Suburban. i was going to run the hot wire up to the #49 fuse under the hood but that fuse is labeled center high mounted stoplamp.
anyone have suggestions on a switched power fuse to use?
thanks,
Cris
AaronIROCZ
Tomball Tx
I have seen people use female spade connectors and have not had a problem. I got the connector and the special terminals for it but either way works.
F
finman
oklahoma
I picked up the connector at lunch.
it has 1 blue wire coming out of it. what should the process be to plug it into the MBEC and connect my positive wire from the dvd player to it?
thanks,
Cris
veteran111
