Haven't seen too much discussion on gears so I wasn't sure where to put this. I just picked up the 99 Hoe in my Sig last week. The previous owner installed the lift, rims and tires but didn't regear it. Right now the truck has 315/70R17's on it. It looks pretty good but I may go up to 325's to get a full 35" tire.
The tire to gear charts tell me at 65mph I'll be turning the following RPM's with 4.56 Gears:
315 - (3rd gear 2898rpm) (OD 2017rpm)
325 - (3rd gear 2852rpm) (OD 1985rpm)
Right now with the 3.42 gears and 315's I'm turning about 2173 in 3rd gear and 1513 in OD. With the 3.42 gears its having trouble getting out of its own way. Its getting about 14 - 14.5 mpg with mixed driving.
If I stay with the 315's is 4.56 going to be the best gear or should I consider 4.11? 4.11 would put me at 2612 in 3rd gear and 1818 in OD. I noticed most of you running 35" tires are using the 4.56 gears.
What kind of gas mileage can I expect with the 4.56 gears compared to what I'm getting now. The drivetrain is totally stock right now and will probably stay that way for a while yet.
I read somewhere on a forum that these trucks reach their peak torque at 2800rpm so you should run a gear that puts you near 2800 in 3rd gear. Is that just taking power into consideration or would that be the best for fuel mileage also? This truck will be a daily driver.
Whats confusing me is the stock tire size on the door of the truck is 245/75R16. With 3.43 gears it would have been turning 2451 in 3rd gear and 1706 in OD. Thats alot closer to how the 315's would perform with 4.11 gears.
