Garmoe
Minot AFB, ND
"try to find where the squeak is coming from when the driver side front tire bouces or is hit."
I had something very similar going on with my yukon. Squeaked every time the front wheel moved at all. Turned out to be the rubber bushing on top of the shock. I took it out and replaced it with another i had laying around and now the squeak is gone
thanks for that. i actually found it was that today as i working on the hoe again. sadly i didnt finish what i started. but will next week
OHSIXX
Milwaukee
Drove it in the pouring rain to run errnads...now in the process of cleaning it up....I know OCD...right :D
Z-56 Hoe
What do I do????
Houston
Re-did the rear bumper cover with new 3M tape. Removed roof Rack, Swapped in a new EGR valve, wash Her, RE- painted passenger side brake calipers. Now I am thinking of ordering her a Black Hitch step.
Pachanga02
Ny
Cut and welded the pass. side brackets and finished installing 07esky running boards. Pics coming soon.
NJ04HOE
Paterson, NJ
Got my alignment done, wheels balanced and put on my 26's.
Now I have to figure out what to do about the tire rubbing on the trailing arm!
Sent from my iPhone 4 using Tapatalk
Garmoe
Minot AFB, ND
smelled burning trans/diff fliud.. turns out the girl behind the counter gave me the wrong fcuking seal!!!! so i have to go back tomorrow to get the correct one.. gah!!!!!!!
03tahoe2012
Plano,TX
Got my sonars in today! they look amazing!!!
also pics of the back up camera i installed and the subs!
jdpber
GOLD MEMBER
The America
Where to start.
Pulled te dash to fix the headlight sensor in center dash. Then installed a powered antenna. Put a fresh coat of vinyl paint on the passenger side. Next I installed an 85 watt light on rear bumper for revers and aux..
I then tinted my buddies. Taillights on his 2011 durango. Then started pulling wire for 2- 12s... Decided that we are pulling out his cargo boxed where the 3rd row should be... It's the HEAT edition... I'm gonna build a custom hidden box in the floor. I need to take some measurements see my airspace. 2 15s is the goal. All hidden
JochenWoern
Sacramento, CA
Easy Fix, ................ go back to 22's or 20's
---------- Post added at 08:26 PM ---------- Previous post was at 08:25 PM ----------
Hmmmmm, what does that Signature Pic remind me off?????? ;)
Washed her up but not time to take new pics now that the center caps are on...
BillBlatt18
Latham, NY
Ordered some canbus style 194 bulbs for my dome lights last night to see if they do indeed solve the dimming LED problem we found a fix for (curiousity is killing me, wish I'd known about those earlier)!! Also ordered some other LED interior goodies as well, now just gotta wait for hong kong to crap them out in the mail for me!! lol
Nice! I finally got canbus festoons for the back row switched ones now
Sent from my Galaxy Nexus using Tapatalk
Rivieraracing
Right on, glad you tried those and they worked! If they work on mine, I'm pulling out my wire fix!!
Also, if you get a chance, can you take a pic of your 3rd row light that has the manual switches on it for me? If its the same as mine but with switches, I'm going to find one here locally and switch it out!
Sweet bike sumo!!
BillBlatt18
Latham, NY
will do tomorrow
wwiizz
