2012 Escalade Premium Dual Exhaust Rear Fascia/Bumper COMPLETE
soulsea
Bar
I agree with that Robbie ... but width isn't the issue so far as I understand it, diameter is. In my experience 'donut' spare tires are carriage wheel thin but they retain the same circumference as the regular wheel/tire combo ... or am I mistaken in this?
IF the circumference/diameter is the same, no matter how thin it is, logic dictates that the problem will persist.
Is this right? :think:
THE YETI
THE YETI
Director of Operations
South FL
You used the exhaust from a Hummer H2? Any issues fitting it?
:superhack:99% complete:weld:
You keep editing your posts and removing information that could be useful to other people in the future!! :banghead:
Done :cheers: This Exhaust modification required too much cutting and welding:weld::weld::weld::weld:
Too bad you've edited every single one of your posts so that no one can gleam any information at all from what it took to get to that point :flipthebird:
soulsea
Bar
Meh Jacob ... all he really accomplished is installing a bumper and an exhaust as they were meant to be installed. Oh and he drilled an unnecessary hole in his brand new bumper for lack of listening and thinking things through.
Not much, if anything, has been lost. :)
NathanJax
Vacation Nathan
Jax, Fl
:laughing1:
NathanJax
Vacation Nathan
Jax, Fl
with spare tire... money shot!
soulsea
Bar
Not for long in that config ... that truck is about to set its own ass on fire.
Or at least melt the spare tire slowly to the point of being unusable.
Good try tho ... but for the fire.
What's that smell??
NathanJax
Vacation Nathan
Jax, Fl
2" of clearance between the pipe and the spare tire. Is enough :hands:
I'd imagine if you really needed to you could put a heat shield around it as well. But yeah, 2" should be enough I would think...
soulsea
Bar
I see ... so basically GM puts a huge heat shield on all the other trucks who's exhaust pipes are by the sides of the truck cause they love spending extra on unnecessary parts.
Hopefully I'm wrong on this and nothing/no oen gets damaged.
Time will tell ...
But it does show that it can be done, albeit better with custom pipes running further down the sides.
It is interesting.
NathanJax
Vacation Nathan
Jax, Fl
Time will tell ...
How far away is the resonator from the spare? I only ask because I bought mine with no resonator or I'd go check.
soulsea
Bar
I'll take some pics tomorrow ... i'm supposed to go to the muffler shop to get my SLP tip installed.
---------- Post added at 11:59 PM ---------- Previous post was at 11:16 PM ----------
The more I stare at those pics the more I think esca succeeded.
Hopefully this won't be another tale of exhaust pipes fubaring or setting the spare on fire ... but it looks like an exhaust shop could push each of the pipes a few inches further out and avoid the potential issue all together.
pmexpert
Moscow, Russia
Maybe it is better to use thermo tape(as for the headers warp) on exhaust pipe to avoid spare tyre heating:imo:
You can look at Thermo-Tec Clamp-on Pipe heat shield also. Just to be sure ))
soulsea
Bar
I took this pic the other days when the truck was on the lift for the exhaust tip swap ... is that the auto ride module or something on the way? :think:
I vote tracking device so that the government knows your coordinates at all time :shrug:
soulsea
Bar
I call them every ten minutes to tell them where I am. :shrug:
NathanJax
Vacation Nathan
Jax, Fl
Serge, that's your air compressor for the air ride...
Jumpshot12
