max load
preshus
washington,IN
whats up . . . i was wondering if anyone could tell me how much they have
pulled with there tahoe . . . iv ben looking for the max load i could possibly
pull with it but i cant find it any where . . . plus i don't have the tow package i
don't think becouse there isn't a button that says tow on it any where . . . im
almost possitive i shouldn't pull a 10500 pound sail boat but let me know
something if ya can
_Dylan_
STAY FROSTY
You need a 3/4 truck to pull 10500 lbs. Don't try to do it with your Tahoe because the brakes are too small and the 2door wheelbase is way too short.
preshus
preshus
washington,IN
ya man i don figured it was to much i didn't wanna burn nothing up . . . but i figured it
should atleast be able to pull a 22 footer that ways bout couple thousand pounds right
. . . my title says the truck ways close to 2 tons so i figure since its pullin its own
weight plus couple more thousand pounds i would deffinatly have to up grade my
brakes or something
Yukon420SEL
PA/ Charleston SC
Was there a tow package available with a button and all for our trucks? i say that because iv got a working trailer brake controller and hitch but no actual "tow" button
preshus
preshus
washington,IN
iv got the same hook up on my truck the brake controller but i know mines
not standerd because its got the original plug pluged into the controll plug
i wouldn't think it came like that but i may be wrong . . .
Ceejkay
Ft. Lauderdale, FL
no actual button, its suggested to put it in 3 while towing. i would honestly say towing the weight of your vehicle would be the most for me.
preshus
preshus
washington,IN
preshus, pass on the details of your year, body model, engine, tranny and gear ratio if possible for a detailed answer.
ight sorry . . . yall know i got this truck off of brynt , or blacked out hoe i
think but its 96 chevy tahoe its got the 350 in it 4l60 tranny im pretty
sure thats right and the gears are 4.10's pretty sure but i could be wrong
its got the 14 bolt axel in it i guess standerd front ifs lifted with 6 inch rcx
suspinsion and 2 inch body if that helps its got the hitch mounted to
the frame and a plug pluged into another bigger plug i was told that's
for brake controll i could be wrong i'd post piks of everything but i havn't
had my truck for almost a month now . . . its currently out of commission
_Dylan_
STAY FROSTY
Do you know for sure there is a brake controller?
The with the short wheelbase, 6" lift, 35s, and stock brakes. I would only tow around 2500lbs. If there was a brake controller I would say around 5000.
Either way you can't tow 10,500lbs with it.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
3.73 was the biggest option gear ratio but with that you can do 6500 hundred pounds of total trailers weight if 4wd drive-train. 2wd setup up will get you 500 more pounds. tongue weight of no more then 10% of trailer and do not let that and internal cargo exceed GVW rating on door sticker. Must have the oil cooler and trailer brakes installed to do anything over a 1 ton trailer. Anything over 2 tons require sway controls. If the tranny get shift happy take it out of overdrive. There should be wiring provisions for a trailer power supply and brake control in addition to lighting power wires.
preshus
preshus
washington,IN
ok thanks sun as complicated as that looks to read it actually helps me
out lol . . . but i don't understand wy would i get 500 more if it was just
a 2 wheel drive . . . if you don't care to answer
---------- Post added at 05:56 PM ---------- Previous post was at 05:51 PM ----------
lol i already knew there was no way to pull that man even if i could pull that
i would not be able to keep gas in it . . . but im pretty sure its a trailer
brake controll plug man its your originall plug that you plug into say a
boat trailer or any little trailer with tail lights and then that plugs into a
bigger plug that ends up being i think an 8 prong instead of 4 prong
i may be wrong on the amount of prongs but im pretty sure thats how
it was . . . like i said i ain got my hoe right now or else id look reall quick
and be sure
---------- Post added at 05:59 PM ---------- Previous post was at 05:56 PM ----------
the reason i ask is because i seen shipping wars last night and found out about
u ship . . . so i figured i could get on there and tow some boats or live stock to where
they need to go since i love to drive my truck and love to sight see and on top of it
get paid for it lol . . . so i was wanting a rough estimate of what my max load should
be . . . . . . thanks for answers
_Dylan_
STAY FROSTY
and be sure
4wd weighs more. Also, say for example you are camping and your truck is packed full of stuff you have to factor that into the tow rating and minus the weight added. The tow rating is measured empty.
The connector on the truck is a straight 4 pin then there is an adapter to a round 7 pin? If that is true there is no brake controller...
Your truck could TOW 10500lbs no problem, but it won't be able to stop or control it. Stock brakes with 35s and no trailer brakes is very dangerous with a short vehicle like yours. If you stomped on the brakes the trailer would push you into a jack knife very easily.
If you wish to tow with your tahoe I highly advise to install a brake controller and always use a trailer with trailer brakes. Also, it would help to have 3/4 ton brakes, hydroboost, and 4.88 gears.
JubjubW
Wausau, WI
.... My Tahoe has seen 10,000 easy....? and has towed more than 6500... 96 4x4 4dr 350 4L60E
preshus
preshus
washington,IN
the wire provisions are there but you would have to provide the 7 wire connector.
your tlkn bout the brake control . . . thats what i don't understand if your
trailer has brakes on it its gonna require a bigger plug right , , , so thats
why i figure since my little plug is connected to a bigger plug with more
connecters or prone's or prongs what ever you may call them then its
gotta be brake control set up . . . but i don't have no box any where
noticable on the truck that would go along with that . . . every one iv ever
seen has a box for adjustment with it . . . but ima shut up lol till i get
piks of what im talking bout don't wanna wear anybody out thats trying
to explain all this to me
---------- Post added at 10:38 AM ---------- Previous post was at 10:34 AM ----------
you have a bit more of an edge over me tho since you have longer wheel
base . . . like stated earlyier my rig can do it no problem its just being
able to control it and stop it . . . hell since my brakes are soft already
it would take 5 secounds for brakes to be bare metal with that kind of
weight on it . . . plus the 10500 pounds being a sale boat about 30 ft
long and most of the weight on the bow it might just tilt my truck up lol
JubjubW
Wausau, WI
Ya, that would make a difference lol... I am just wondering why i saw ratings at only 6500
D Rollins
