Rubbing trailing arm still
ghost
Senior Member
My back driver side tire is still rubbing my upper trailing arm bracket when i take turns and have a few people in my truck. I have the rear hardware kit installed, i thought this was to avoid all that? this kit didnt seem to help my truck much honestly except my sway bar..
heres a pic of the rubbing. and a pic of the stance, you can see the tires are still pushed way forward..
rear set up consists of, DJM 19.5 calmax, eibach 3" drop coils with all the dead coils cut off, and rear hardware kit.
305/40/22 tires, sitting at 31" in back and 30.5" front.
any ideas to fix this? i have been thinking about adj panhard...
Alex33
Zac, any idea what the clearance is on the pass side in the same location? My guess is that the adj panhard bar will help. Any pics of the truck from the rear where we can see both rear wheels and the clearances?
Tahoewhat
Ballin' on a Budget
TX
The hardware kit, to my knowledge is only to move the rear forward and center it, from front -back area. The ADJ. panhard you can move the rear left and right. Like alex said, if the other side has more space, then when lowered yours shifted to the side that is rubbing. Get a adj. panhard and just measure it and align it accordingly and shouldnt rub again.
Omar
cutting dead coils? how did u do it?
how is the ride?
Modded
That Guy
.......... with all the dead coils cut off.......
That's the problem right there. Those coils being cut is leading you to be lower than normal and have a stiff ride.
ghost
ghost
Senior Member
I thought they were suppose to push wheels back?
I will get pics of back later..
As for dead coils, they are coils that when loaded they sit on top of eachother. Basically just taking up space. So when cut off it makes coils shorter, which is why I run a shorter shock or they would just fall out.
The ride is pretty soft. IMO I like it better than when I had djm tb coils
ghost
ghost
Senior Member
the eibach coils cut ride much better than the silver djm tb coils that i have.. i cut them to be lower because they dont make a coil to bring me down that far. so why not cut a coil that has 3"s of dead coils on it?? just my 2cents. ive had almost ever rear set up on the djm calmax shocks and this is so far the best riding with out a doubt. i still need to come down half an inch...
Tahoewhat
Ballin' on a Budget
TX
yeah, push them back to center it in the rear. Didnt really help mine, more of a problem, b/c i had to really push my rear forward and is smashed driveshaft into the trans. So mine didnt go back, it went forward.
NORCAL SS
SUV SUSPENSION GURU
belltech 5305s will sit lower.
ghost
ghost
Senior Member
Yea the brackets are a waste of money IMO. I think for the money and functionality the adjustabl lwr, n upper swing arms, plus pan hard would be the best bet. I want to say WHITEOUT has a thread somewhere on ordering these bars for pretty cheap...
---------- Post added at 05:30 AM ---------- Previous post was at 05:28 AM ----------
The 5305s are too tall of a coil. How big are they compared to djm tb coil? What heights would I be looking at? Remember I need to be at about 30.5" on 305/40 tires
WHITEOUT
Dont Hate-Appreciate
Phoenix
ya, pickup the adjustable rear lower control arms, have thread somewhere. can't remember haven't been on forum in awhile!!! need to start coming back on more!!!
As for rear hardware kit, arm brackets, just move control arm back upwards to OEM placement. IMO, doesn't "need" to be used, but helps bring lower control arm into correct location. I still haven't gotten upper rear adjustable control arms yet, so I can fully put axle by moving it backwards into correct position.
Ghost- rigs looking good bro!! liken how low it looks with cut springs. I grinding m
ine alittle to get 1/2" lower, but might cut some dead coils as well. just worried it will be TOO soft.
I need to post new pick, ride looks alittle different now ;-)
WHITEOUT
Phoenix
very nice link Norcal SS. those uppers are what I want/need now.
BUT..... You can get the panhard bar and rear lower control arms for more then half the price less , by getting some made. Just 4 link adjustable bars really. I had mine custom made, adjustable, with poly bushings., just like Spohns, for $50 apiece. only difference is panhard bar isn't "on car" adjustable!! so what really, once u set it, won't have to again. just metal threaded tubing, adjustment nuts, poly greasable bushings, and welds were top notch!!! IMO, just as good, and price is way cheaper by getting some made by a air ride company. I like Spohns stuff, and not downing there products at all. just can't justify price for the panhard, and lower control arms, and just letting people know they have other options.
Just my .02¢ on it.
ghost
ghost
Senior Member
cant wait to see the new look.. i have been playing around with a lot of dif set ups for my susp. right now it is riding better than anything so far. spindles, keys, and bt drop shocks in front. keys are cranked exactly half way.. rear is pretty soft, but i needed the soft ride with these rough ass roads i live on lol. the DJM TB coils were way to stiff for me.
I know ive hit u up in the past about them rear adj arms but i dont remember where you got them. PM the info on that if you still have it.. i NEED to get them lol rubbing bad..
NJ04HOE
Paterson, NJ
Hey Ghost, did you ever get this figured out? I'm having the same issue now and I'm pissed!
Sent from my iPhone 4 using Tapatalk
ghost
ghost
Senior Member
yes i did. i still havent done the proper fix but i ended up grinding down the upper trailing arm bracket a bit, not much, just enough to not rub for now. when i get off my ass, ill buy the same adj panhard bar that whiteout had made. you can allways go the sophn route but then your really looking at about tripple the price.
NJ04HOE
Paterson, NJ
That's what I was thinking about doing too. I'll get the spohn later but for now I'll use the grinder.
Thanks
WHITEOUT
Phoenix
Tahoe is looking good Ghost!! Love that look, white w/ black accent!! Man, I love the way mine looks now, but do miss that style. Good job bro. Cool u got it temporarily fixed. But ya, u need a panhard bar to move those wheels over. Like I said, Spohns sh$t is really nice, n they take the guess work out of it. But when u can save yourself half the cost by getting some made. Sh$t, ill have $350, once I get Spohns upper arms into the same setup that would cost $600 thru Spohn. Could get the Del Sphere bushings added n still save money. Just saying, that's a tune, and not downing anyone for getting them!!! Im not cheap, just like having more then 1 option, and I really like money, haha . Almost a year since I got mine, still working great, no issues
ghost
ghost
Senior Member
thanks whiteout! im really needing to change something tho. I like the look myself, and although a lot of people consider it "played out" i think it comes down to how well its executed. Anyone can throw some chrome or black or polished wheels on a car, but if it doesnt flow it dont look right. I do need to do something to her to set if off a lil dif than the rest. Just at the point of where i dont wanna put any more money into it! LOL or maybe Im just getting tired of her i guess, maybe because I now drive 3 times as far to work everyday and gas is starting to wear on me, and because im about to roll 100k! so now im worried about problems and so on.
haha sorry for the rant! been at work since 5am and had a whole pot of coffee!
---------- Post added at 09:58 AM ---------- Previous post was at 09:51 AM ----------
This is the first truck/car ive owned that ive never stopped putting money into! Its never ending! Every other vehicle, I drop it, put some rims on it, maybe change a few other things and call it good. Then sell it after a year or 2. This one for some reason im just never satisfied with. Ive had numerouse set ups for suspensions and just cant dial it in. Still rides rough, a few squeeks that i cant find on the outside and inside, but Its hard to part with cuz shes payed off and only has a 96k. Also, they arent selling anywhere near their value around here... theres 1000s of them on craigslist
Alex33
I'll second this!! Once I started going from a twice a month fill up to a 6 times a month fill up, it definitely started to wear on the wallet. The only difference is mine has 175k on it. It has little squeaks and such and I'm starting to get more from the interior than anywhere else. Oh well. I still enjoy it and I've committed myself to keeping it for a while. to fix the gas problem, I got a beater. Now I don't wear on it anymore, yay :D
WITCH1975
