01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
Sweet I was asking because it says not to cut wires but then you can't splice because there for cut wire idk I'll have to wing it or solder and shrink wrap
OHSIXX
Milwaukee
Yeah it might be the 'correct' way but I've done that way in the past. Just skin em' back and use some electrical tape and PRESTO-your done. The true audio guys would frown without solder or shrink but hey......
chauncey0337
MLT, WA
Soldering would be ideal but I would advise you to at the least crimp them. If you just twist them together that just adds more resistance and could cause the load resistors to get even hotter.
chauncey0337
MLT, WA
Yes, CRIMP!
JochenWoern
Sacramento, CA
Well got my 2 packages from FedEx this am and installed the rest of my stuff. The popcorn should be gone by now fellas.......
(1) Installed new LED's in front parking lamps along with load resistors. I went with these because with the clear housings and filament bulbs--they had a orange tint to them from the bulbs so they didn't look as 'clear' as I wanted them to. Problem solved.
(2) Installed new 'smoked' LED tails from x3 racing.....the ones everyone else has. Was gonna originally tint my stockers but went with these-it gives the rear a whole new look-maybe time for Esky vent caps next ;)
(3) Picked new carpeted front floor mats with 'DENALI' stitched in them. They are from a company called Lloyd Mats.....great quality. Also grabbed a keychain cuz' what the hell ;)
Onto the pics:
LED parking Light Bulbs
'x3racing' LED Tails
Front Floor Mats
That's it....for NOW :D
-J
Looks AWESOME Jason!!!!! Same smoked tails I have. Hope you love them as much as I love mine!
AND YES, definitely ESKY CAPS, it will look so much better back there.
---------- Post added at 12:49 AM ---------- Previous post was at 12:41 AM ----------
Onto the pics:
Front Floor Mats
-J
Looks AWESOME Jason, love the smoked tails, same as mine.
Yes, I think definitely ESKY vent caps!!!!!
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Oil change with Wix filter, synthetic oil, and Lucas oil stabilizer. Installed Sylvania Silverstar Ultra bulbs in high and low beams. Reunited to install GM Accessories auxiliary trans cooler. Cooler is mounted, bury lines are not attached. Won't be able to continue tomorrow because the wife wants to go to the car show. Maybe next weekend, and I'll do a complete trans flush and filter replacement at the same time too.
Sent from my myTouch_4G_Slide using Tapatalk
OHSIXX
Milwaukee
Thanks man.....yeah I like the 'new' look......can't believe I waited this long to get them....
I agree on new vent caps-just trying to decide between the Esky and the smooth SS ones.....
-J
JochenWoern
Sacramento, CA
-J
For me, definitely ESKY. I think they just look classier then the smooth ones. But that's only my opinion.
jwhaler17
Installed green LED on headlight switch assembly to indicate when headlights are on... Installed new Katzkin leather seat cover on passenger seat (ran out of time for the others)... installed LED bulbs in the map lights and overhead lights...
Biggmann
DMV
Was gonna say check the balast but i see u did.. it appears to be a bad connection some were.. Try break it back down and reassemble it..
05Yukon23
Arkdelphia, AR
Windshield wipers and seafoamed the Yukon. Nice smoke show! Not nearly the smoke show that my brother's tundra had for us though. CRAZY amount of smoke from his.
Tahoewhat
Ballin' on a Budget
TX
Biggman sweet!!!
And failed with my hids today
You know what, the ones i recently reviced from DDM for my buddy sierra, does that same exact crap. The headlights come on sometimes, but not so bad, the fog lights come on for about 5 seconds then go off and one side flickers on and off. One side i got working, but the other, is just like your vid. Only one side goes wacko
Wonder if they have a bad batch of ballasts/wiring, (which i have got before, and had to rewire thier stuff)
if you get a fix, let me know.
TheYuk
Atlanta
If you're not running a relay they will do that sometimes. Mine did this until I did relays.
Hodmjstone
