blower motor replacement on 2004 escalade
beav626
Pretty Girls in your city for night
Usa
how does one replace the blower motor on a 2004 escalade ???
Thanks,
Keith
Super easy-
remove the black plastic trim under the glove box (2-3 screws) it is the bottom of your dash
from there you should be able to see you blower motor.
I believe you have to unscrew the resistor and then the blower motor just rotates out.
reverse process to put it back together.
K
Kfarron1
Latham, NY
Thanks!
I also just looked up on the chilton manual online, seems pretty easy, I have an 03' yukon denali xl and my brother has a 04 escalade, which the blower motor crapped out on, so I figured I'd replace it for my father in law.... As long as it was easy hehe!!!
ajaxnxs
Rockwall,TX
Clean the housing and the coil while in there.
Sent from my Motorola ATRIX using Tapatalk
gdddup
NJ
its not hard just tough to fit a large body in there
Mike1980B
Lacey, NJ
i have a 03 Tahoe. And my blower motor only works on HI. could it be the motor going bad or the resistor bad? any help would be great guys
Drewphil
