No Sound
puckhead
CO
Started my truck up the other day and no sound. Hit a bump and then it was back. Now its gone again. Looks like I will be tracing some wires to find a loose wire maybe I should just replace the whole system!?!? lol
Edit:
So I thought it was good to go after wiggling some wires because it was working. Nope. Now its off and on, working more, but still going out. I re-did some of the connectors and fixed some stuff that the idiots who installed my security system did. Nothing! I thought for sure it would fix it.
And I just went and looked at the amp behind the glove box. Everything looks fine. Didnt take it out, everything back there is too tight.
Well SOB!!! I unhooked the speaker that I thought it was and it worked for a bit, now no more. WTF, I am pissed. About to rip everything out and start over.
Any way to narrow it down to a certain speaker?
I really think the guys that put my alarm in did something dumb. It has a lifetime install warranty but I don't know if I trust them to fix it. Headache!
TnTahoe
TN
If you got the money I would say go for it
NoPh33rRaCiNg
Kent, WA
Stock system? Start with the factory amp plugs. There's a plastic plug in and one going out of the amp.
puckhead
puckhead
CO
Stock speaker set up. After market head unit and subs.
Now I gotta figure out how to get to the amp.
NoPh33rRaCiNg
Kent, WA
If you get no sound from anything, I'd start at the head unit.
This too ^ I didn't know you had aftermarket headunit. Check for a loose remote turn on wire (blue with white stripe) check the factory amp. If it's non bose its behind the glove box, just flip it down and you can see it.
puckhead
puckhead
CO
Thanks guys, this will be my project in a few hours. First thing I was gonna do was pull the HU. So I will check the blue wire, thanks!
chauncey0337
MLT, WA
puckhead
puckhead
CO
Haha! I let the suspense build all day lol. Well I pulled the HU and checked all the wires. Everything seemed good. I must have wiggled the right wire cause it works again. Im gonna leave it for now. If is starts up again I will have to start undoing my connections and then redoing them.
chauncey0337
MLT, WA
LOL. I didn't even notice you were in WA.
Yup, just an hour north of you.
Hope it stays that way.
GeneralNoobzor
Phoenix, AZ
Look at your cup holders while in the driving seat. Put your hand on the right of the cup holder and pull towards the passenger door, while doing that, pull up. The cup holder will come off. The factory amp is located here. There will also be a blue plug that you have access to that connects the wires from the amp to the speakers. make sure it's nice and snug. If this isn't it take apart the back of the center console and the middle (4 screws for console lid, 4-6 screws underneath the mat inside, and 4 in the back. Oh and 6 on the top. ALL phillips. You will have access to the amp better. Make sure the plug is also in here. :)
puckhead
puckhead
CO
GeneralNoobzor, my amp isnt under the cup holder. I will have to figure out how to get to the one behind the glove box. Anyone have advice for that part?
ScottyBoy
Shreveport, La
If you still have your original stock speakers, then the speakers are most likely to blame. I had the same problem with mine before I replaced them. What's happening is that the copper wires from the speaker terminals to the speaker cone have become broken and/or loose. When you hit a bump, the two wires touch each other. When they touch each other, the sound is cut off to all speakers because its shorted out. When you hit a bump again, the wires come loose and the found starts playing again. Next time it happens, slap each door near the speaker. When you hit the bad speaker, the sound will start playing again.
puckhead
puckhead
CO
Thanks Scotty Boy! I did not realize that it would short all the speakers out. I know exactly which speaker it is too. passenger front has been going out for a while. Guess it finally did it. Well, might be time to buy those new speakers I wanted. Spending too much damn money lately! Maye I will jut replace the front for now and go from there.
Thanks again bud.
ScottyBoy
Shreveport, La
If you at least unhook that pass side speaker until you get a new set, then the rest of the speakers should stop cutting out on you.
puckhead
puckhead
CO
Any way to narrow it down to a certain speaker? I really don't want to buy all new speakers right now. Ive dropped over $3k this year so far in vehicle and computer repairs.
chauncey0337
MLT, WA
Is there ant way you can call the people who installed your alarm and tell them you've been having a problem ever since they installed it?
puckhead
puckhead
CO
Yeah, but I would not trust them to touch my ride again. Might call and see if they would have tapped into some random wire or something and see if I can track down the bug.
I am going to try and unhook the driver door speaker and see if that is the right speaker tomorrow. It is the one that always opens and closes so it would make sense that it wiggled loose.
SuburbanPassion95
