JochenWoern
Sacramento, CA
Looks awesome Jochen. I don't think I would worry about that gap at all.
Looks really warm at your house, by the way. It was overcast and just got over freezing here in Michigan. :emotions122:
Thanks Nathan.
Yes, it was 33 this morning, but got up to 65 this afternoon.
Tahoewhat
Ballin' on a Budget
TX
Looks really good Jochen. Caps and Rack all goes together.
felixgun
Lafayette, LA
Thanks Mike. Feels good to get approval from my buddies. :)
I am still somewhat getting used to it and am hoping I am not having too much chrome on the rig now??????
Looks great Jochen! Now that you mention the chrome on the front and rear bumper could be switched to the NBS Denali front grille and rear bumper. Both of which are color matched versus chrome. You should consider it in the future... After the Esky third brake light and glass :)
soulsea
Bar
You guys are terrible ... let him enjoy today for Gunter's sake. :)
soulsea
Bar
Well, I love what you've done so far.
I absolutely love the NBS Denalis like Jason's truck. However your theme is incorporating chrome whereas the Denalis colormatch everything. So I'm not sure how all that will work together if you start mixing Denali trim with your chrome.
When I see you truck the only thing that I see that I feel doesn't do it justice is those nerf bars ... I'm not loving those all that much. But I'm not sure what your options are in that regard.
NJ04HOE
Paterson, NJ
I finally did the free travel mod today, replaced my rear coils and added helper bags...the only problem is the drivers side is sitting higher than the passenger side and I'm pissed!
Sent from my iPhone 4 using Tapatalk
JochenWoern
Sacramento, CA
Thanks very much Serge, I do appreciate it.
I will not mix the Denali trim with the Chrome and the more I look at my rig, the more I like it. I think it looks great and I also think I will leave it as is. Not sure about that ESKY thrid brake light and glass.
In regards ot the nerf bars, I guess it is a matter of taste. I do like them and I do need them in order for the kids to be able to get in and out.
Other then Nathan (LuSe4), no one commented on the bigger gap question between glass and Vent Cap?
Thanks.
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
Without corduroy!
- It appears that the gap between my rear glass and the vent caps is now quite a bit bigger then it was with the original caps. I want to say at least a 1/4 inch more.
-----> Is that normal/possible due to the tolerances of the plastic piece?
-----> Anything to worry about?
Thanks.
yes there's going to be a gap because the esky third brake light flares up a 1/4 inch higher then kons and hoes... Only way to fix that is to get the esky third brake light :D which looks like a direct swap with your Yukon since the glass is shorter than most
JochenWoern
Sacramento, CA
Thanks Garry, that makes sense.
---------- Post added at 12:20 AM ---------- Previous post was at 12:17 AM ----------
Looks great J dubya! As for the gap, not a big deal but I can tell it bothers you.
Thanks Chauncey.
Now that I know there is a reason for the gap (thanks again Garry), it no longer bothers me at all.
I just could not figure out what was going on there and I also could not figure out what I could have possibly done wrong during the install.
It's all good now though, thanks again!
01HDtahoeNJN
North Jerz, NJ
I thought the same thing when I put mine in haha.. Everything looks great btw jaydubya.. I want to do esky 3rd brake light but need the light wing and hatch glass your one step ahead seems your glass would work easily....
I received the biggest part of my much needed 1999-2002 HD front end aka HDHO
The HD grille!!!
Will look something like this but with a color matched bumper cap
jdpber
GOLD MEMBER
The America
Jammed some crisp warm tunes on the drive to the office... need the next step in my audio build.. yes its an ongoing build to SQ greatness...
01HDtahoeNJN
North Jerz, NJ
Is there a how to link for this!?!
JochenWoern
Sacramento, CA
The HD grille!!!
Thanks.
Is there a difference between the Yukon and Tahoe rear glass? Why would mine work?
OHSIXX
Milwaukee
I'm wondering the same thing about mine...which glass works and which doesn't. Are you able to just 'add' the third brake light assembly?....I thought I read they were epoxied in place to the glass........
kses123
kses123
Raleigh, NC
The Tahoe/Yukon glass is the same. They had the plastic hinges moulded onto the glass from 2000-early 2005. In 2005, the dropped the moulding around the glass and its just flat with a handle screwed into the glass. The hinges became metal and were glued to the glass. Also, in 2005, the Tahoe/Yukon glass got that plastic applique piece at the top. It is held on there by three screws and 3M tape.
The Escalade glass had the same moulding around the glass until 2005. It then got the metal hinges, etc. The applique that holds the brake light is held on by three screws and 3M tape. Unfortunately, the three holes are in a different spot on the Escalade glass compared to the Tahoe/Yukon glass.
You can always just buy the Escalade applique and brake light and 3M tape it on there. That stuff is really strong and would hold up just fine. You could add as much as you'd like. It is much cheaper than buying the $600 glass/brake light combo!
OHSIXX
Milwaukee
Thanks a bunch for the clarification.......guess I will be on the look out for a third brake light......I've used 3M tape in the past for body moldings and such and the stuff won't let go without a good fight ;)
Mountain Rambler
