abladeafficionado
- Joined
- May 10, 2011
- Posts
- 148
- Reaction score
- 0
I have a 2001 Denali with that style dash. I'd like to do a backup camera for backing up at night, hooking up the quad/boat/travel trailers alone, etc...
The 2003 and up have that little pocket where my OnStar is located that works perfect for many of you guys on the forum, but unfortunately, I don't have that.
Has anybody found a good place to mount the monitor?
Here's my idea:
Most everybody has seen how a power flip out DVD works. They slide out of the pocket, and then a motor turns "flips" them up. They consist of a sliding channel to slide out, and then a pivot that goes up 90º, and then slide back in, so that they sit semi flush, while neatly tucking away when not in use.
I wonder if a manually actuated flip out could be done in my OnStar pocket? A simple tab mounted on the top of the monitor could be used to pull it out of the pocket, flip it by hand, and then slide it back in. The biggest struggle would be finding a channel and pivot that could be built to be low profile and work. Chances are, it'd have to be custom fabbed. I think it could be a pretty cool way to do the backup camera install if I can figure it out.
Does anybody have any ideas on how to make that happen? If there were some pre made stuff that could be adapted to make that work, that would be awesome.
That's plan B lol, I'd much rather find a good place to mount one that looks clean. Unfortunately, I'm just not seeing a good place for one.
Wait, why can't you just connect it to the back up camera?
