New Air Bags and Rims
B.G.
I removed my spare since I can't use it with my brakes. I also had the panhard bar moved so the rearend could be centered. I don't have the kit the installer (Chassis by Aaron Iha) used what he thought would work best.
Thats super clean man.. u cant see anything, the way I like it:mexsmoke: If you dont mind, what did your setup set you back?
yates ™
Resident Apple hater
Iowa
I have always wondered Nasty what controls are you running?
NASTY GM
Nor Cal
I paid $4400 parts, labor and powder coating :mexsmoke:
yates what do you mean by controls?
switch box - AVS
Valves - Asco
yates ™
Iowa
The kit that mastiff and I run is an AccuAir system and didn't know if you ran just switches or if you have an actual control system.
sick1166
just wondering how this works? I have a 07 tahoe ls no air just springs and shocks .This kit do you just pull out yor old coils and shocks and replace it with the airbag system? im new at this tahoe deal so sorry for stupid newbie questions.
chadman
I read in the manual you can't drive with no air in the bags because it might damage your vehicle. Does anyone know what might get damaged? Is it because there is no travel in the shocks?
And is there some kind of warning system to stop you from driving if you have the air out of the bags (lowered all the way)?
yates ™
Iowa
You will just be driving on the struts. You can damage the bags, struts, the sensors, or possibly wreck. Nothing but common sense will stop you.
sick1166
just wondering on a stock 2007 hoe ls if I need to put in a lowering kit or any suspenion mods before the install? or can I just add bags to my stock suspension and get that drop? thanks
yates ™
Iowa
Remove the stock springs and the bags go in their place.
sick1166
on the instructions it says to use the stock sensors which I dont have can those be easily installed also? and would this kit look good or work with 22" or it would not just look right
thanks for the info
yates ™
Iowa
Their is aftermarket sensors that you will use. I did not have factory air ride so I use the aftermarket sensors.
Sorry best pic I have
chadman
How does the ride compare to the stock autoride suspension? Is this kit give it a softer ride?
M
mastiff
I didnt have the auto ride before. But i can tell you this, once you ride in a truck with air you'll never go back. This truck doesn't have a floaty feel to it. It's kinda hard to explain.
M
mastiff
Just to let you guys know. I f you know or if you are looking, this Yukon is for sale. Looking for $35,000 And it will include stock suspension. I can't post in for sale Adds because I don't have enough regular post.
Drewphil
