What could it be?
96_2DRSPORT
Paper Chaser
Baltimore
Good Evening TYF
Im having starting issues ITS NOT STARTING LOL...I took it to Autozone for their "free" code check and it came up as cylinder 6 misfire and 02 sensor bank 2...I just replaced my alternator and battery maybe 2 1/2 weeks ago could their be anything else im missing?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
p0155 is a heater malfunction of right cylinder bank o2 sensor just behind the manifold on the exhaust pipe. Replace it .
p0305 is a #5 misfire. Check the following:
  1. Check the spark plug wires and the coil wire for the following conditions:
    • Ensure that the spark plug wires are securely attached to the spark plugs and the distributor cap.
    • Check the wire routing in order to ensure that crossfiring is not occurring.
    • If the misfire occurs when the weather is damp, the problem could be due to worn plug wires.
    • In order to test for this condition, spray the wires with water and with the engine running, watch for spark to jump from the wires. If a spark is visible, replace the wires.
96ProCompTahoe
IN
First off pop the Distributor Cap off and see if it is corroded. have to clean mine usually once a year around here. does all sorts of crazy shit when you hit the key when it gets gunked up.
96_2DRSPORT
96_2DRSPORT
Paper Chaser
Baltimore
yeah i just changed the distributor cap maybe 3 mos ago
vsaravia
