Dropping the Back for Level?
waxworkz
3" springs will get you 1" too low in the back. i believe the rake is only 2" lower in the back??
waxworkz
i think the 2" drop will level you out. springs should take about 10 mins to install. remove shocks, raise truck, let springs fall out. put new springs in, lower truck, install shocks. drive off
waxworkz
yeah but even with shock extenders you will loose some ride quality. at least i did.
waxworkz
if i were you i'd try with out first. honestly 2 inches isnt a huge difference. your suspension will bottom out before your shocks do. if anything upgrade your shocks, depending on the current condition.
vsaravia
