coolant flush?
alc5m
how do i do it, how much coolant comes out, how hard is it
these are all questions im wondering, i have brown coolant in the resevoir and its only a matter of time til it gets real brown in the radiator cap, so id like to take care of this
my friend told me pull the drain on the radiator, then open the radiator cap and just run a hose thru til its clear, but idk if thats right or not
any help would be appreciated
and 96 with a 5.7
SunlitComet
OBS Jedi-Do Good
unknown at this time.
get 2 bottles of this:
http://www.prestone.com/node/424
and this kit below:
http://www.prestone.com/prestone%C2%AE_flush_n_fill_kit
Instruction on in the products and the top of each product page.
Drain and properly dispose of old coolant. Use the flush kit and back lush the remaining old out and fill with flush chemical and water run for required time with as much air bled out as possible like describe below when refiling and then back flush system again until there is just water. Flush and empty out your coolant reservoir. The refill with Dex-cool coolant and water. You may have about a gallon of water still in there and the system with a/c carries 5 gallons so put 3.5 gallons of straight coolant in. It will get you the best freeze and boiling point temperatures. It will not go in all at once the best way to get the most in there at first it to remove the thermostat housing and stat slowly fill the radiator until you get the level right up to about 1/4" below the gasket seat. Get a new 195 degree stat and gasket and reinstall the housing. continue to fill while squeezing out air from the upper hose as much as possible. Start engine and add some more if the level drops more when it starts to rise out of the cap opening reinstall it. Fill your reservoir to the hot line the first time. drive with your heater system on for a bit making sure the system gets hot and let it sit and cool for a long while. As it cool it will take coolant from the reservoir to fill the air gaps inside that bleeds out over time. It will take two or three complete hot cold cycles to get the last of the air out. Keep an I on the reservoir and never let it get below the hot or cold marks. check it before you drive and after. Make sure to keep your heater on during all these processes. Put fan on lowest setting and temp on hot setting. Do not move fan switch to off position. Eventually it will be maintaining the levels with out having to add more coolant. And keep a pre-mix 30 water/70 coolant supply around.
As about as good as it gets for a clean system.
Does that help?
A
alc5m
thanks a lot sunlit, best help on the forum comes from you man
puckhead
CO
Nice write up sunlit! Thanks! I will have to do this next time I do it instead of taking it somewhere.
Dh1280
