Procomp 6", ford keys, 1.5 coil spacer, 37s???
ekordas
already got ford keys and 1.5" rear coil spacers cruisin on 33s on my 02 XL. thinkin of going with the procomp 6" suspension lift with my ford keys and coil spacers. not a fan of trimming any metal body parts, plastic im okay with tearin apart. think i can fit 37s with this setup? to my understanding, however much the ford keys and spacers lifted me past stock, thats what they will give me past the procomp lift specs correct? my wheels are the KMC rockstars
brucebruce45
Street riding you should be fine. Wouldn't offroad it'll more than likely rub depending on ur width an offset wheel choice
E
ekordas
Bruce I see you got the procomp 6" lift. Are you happy with it? How was the install?
brucebruce45
Install is gravy. Kit is pretty straightforward. Mines a 2wd so I added 3" rc spindles an 1.5 zone
McAllister513
Same here you will be fine but i'll tell you now its gonna rub! Do yourself a favor and go ahead and get a zone 1.5" BL!
At first I didn't want to but I really like mine now that its on and I don't have to worry about scrubbing!
E
ekordas
The only body lift I see that zone sells is a 3"
E
ekordas
How difficult is the install on the zone 1.5 and the 6" suspension? Looking to install it all myself
Max
Mile High
Denver
You should be ok since you have 0mm offset 18s. Really depends on which tires you plan to run.
rossida
