Navigation/ DVD question
photoryan
Orange County, CA
I have the OEM Nav system w/ backup camera. But from what I found on the factory codes, it appears that my system doesn't have DVD. I have also tried sticking a DVD into the disc slot and it just kept trying to read it, but nothing ever came on (yes, I was parked- not driving).
Does anyone know if there is the possiblity of getting something that would allow DVD's to be played in my system? I don't want to purchase a whole new system, so that's out of the question. I would be willing to get the GM Lockpick if it did allow DVD playback, but I can't tell if it can or not.
ChevyFreak
New York
Do you have a factory rear entertainment system? If not, then your navigation system probably does not have DVD playback capabilities.
Just to be sure check your unit for a DVD symbol. I have provided a picture (look in the red circle). If your unit can play DVD's then this symbol should, theoretically, be visible.
As for your question about the lock pick. I would say yes and no. I believe the lock pick, at least the GMX550 has an audio and video input. I would guess that this would allow you to plug in an external device (a separate DVD player) and allow it to show on the screen. I have not tried this myself, so I cannot verify that functionality though. Either way, if your unit does not have DVD functionality I think you are out of luck using the unit as a standalone DVD player.
I hope that helps. Let us know what you find out. Good luck nonetheless!!
P
photoryan
Orange County, CA
It does not have the rear seat entertainment system, nor the DVD symbol. So, that's kind of what I thought. Hopefully someone will chime in about the GMX550 on the aux input piece. Even if I can end up playing movies through my ipod, that would suffice.
ChevyFreak
New York
Now from your ipod is a different story. That just might work. Start your research about the GMX550 HERE
It may be just what you are looking for!
I am sure some other members can chime in about the lock picks and the issue at hand :)
briannorris
