Fast 5.3
Robert.K
San Diego, Ca
What can be done to enhance this engine? Bb tune is coming after my headers and exhaust get installed. Have a k&n cai on it, superchips tune( for now), Vette servo in the trans, but looking to increase over all performance as a daily driver. Cam? Heads? Thoughts?
Preludepearl417
twin 68mm turbos and meth injection on a 6.0......everything carbon fiber. That should get you going pretty fast. :Big Laugh:
Everything is cooler with a supercharger :rocking:
Z-56 Hoe
What do I do????
Houston
N/A or F/I? either way the 4.8L heads ported and polished, Cam, Maybe a Blower, Trans wise shift kit upgraded turqe converter with a higher stall, upgraded sun shell, clutch packs, lower ratio gears in the rear-end as in 373's or 4.10's an LSD in there also
DaRosa218
The Dude abides
Modesto, California
+1 on the Port and Polished 4.8L Heads, BB Tune and a Supercharger. Once you start playing with Cams in California good luck getting it to pass our super tight smog laws :emotions122:
I have a 97 Jetta with a 16V 2.0L bored 88mm over, port and polished 16V head, Flat Top Pistons, Stage III Cam, 30lbs injectors, Shaved Eurospeed Fly-wheel, T3 Turbo with a water injected intercooler, 4" Piping and it is now a 15K driveway decoration since it wont pass smog :(
Sad thing to remember is it's a heavy SUV that's not very aerodynamic so lots of potential from these motors is lost due to these factors
Z-56 Hoe
What do I do????
Houston
are You Military with an outta state DL and tags if so **** Cali Smog laws~!
rich5368
Cheyenne, WY
I don't know about 4.8 heads. Never done it, but if you want to stay N/A these motors respond very well to cams. It's a heavy truck though so get you one with your focus being on torque as low as possible and a wide curve. A stall and gear will help emmensly. The only downside I see is with the weight of these things if you go too big with the stall your poor 4L60 is gonna be hurting. lol. I do recommend an upgraded Tranny cooler if you stall it as you will be producing a lot more heat through a stall and heat kills transmissions. As for cams and heads I personally would go with the TSP 5.3 PRC stage 2 heads and a 214 or 228R cam. They'll set up the heads the way you want and the combo sells for around $1300. There's guys with LS camaros making well into the 500hp range on those heads. When all else fails you could go with power on a payment plan and spray a little giggle juice. Sorry to ramble so long. Just getting my 2 pennies in.
Robert.K
Robert.K
San Diego, Ca
With that cam and head setup, would I need another cam if I plan on supercharging?
rich5368
Cheyenne, WY
A lot depends on how aggressive you go with the cam. Really good NA cams don't always work well with forced induction.
THE-HOE
Pittsburgh Pa
Juts so you know 4.8 heads are no different than 5.3 heads. There are 2 different casting numbers dependent on what year the head was made. ( Casting Number 706 and 862) but they are both the exact same head used on 4.8's and 5.3's. Both the intake and exhaust valves are 1.89 inches and 1.55 inches and they both have Combustion Chamber Volume of 61.15cc.
ZaZaZazzels
